ISPConfig 2.2.36 released
ISPConfig 2.2.36 is available for download.
This ISPConfig release adds support for new Linux versions, updates PHP, ClamaV, Spamassassin and OpenSSL and fixes several bugs.
Detailed Changelog
- New: Added support for Fedora 13
- New: Added support for OpenSuSE 12.0
- New: Added an option to config.inc.php to NOT have the stats belong to the web concerned, but to root
- New: Added global stats user to awstats statistics
- New: Added option in config.inc.php to make log directories belong to root instead of the web owner (more fair concerning quota usage)
- New: Added random password for admin on installation
- Updated PHP to 5.2.13
- Updated Spamassassin to 3.3.1
- Updated ClamAV to 0.96.1
- Updated OpenSSl to 0.9.8m
- Changed: Encryption of SSL keys is now 2048 Bits
- Changed: Disable webalizer debug setting, can be enabled while actually debugging
- Changed: Cleanup of the installer and interface code.
- Changed: Removed duplicate database indexes.
- Bugfix: FS#509 - anonymous ftp should not list incoming directory
- Bugfix: correctly purge ALL old access logs from system log directory (useful if cron job might have failed to run one day)
- Bugfix: The *automatic* whitelist is not a score that can be adjusted
- Bugfix: FS#887 - Remove hardcoded server_url to allow proxying ISPConfig site
- Bugfix: Added a patch that fixed a compile problem in ClamAV on Fedora Linux 11 and below.
Changed system requirements
This release requires that you have these two new Perl modules installed on your system: NetAddr::IP and Archive::Tar
Installation instructions for the new Perl modules:
Debian/Ubuntu:
apt-get install libnetaddr-ip-perl libarchive-tar-perl
Fedora:
yum install perl-NetAddr-IP perl-Archive-Tar
OpenSUSE:
yast -i perl-NetAddr-IP perl-Archive-Tar
Mandriva:
urpmi perl-NetAddr-IP perl-Archive-Tar
CentOS 5.x (x86_64):
yum install perl-Archive-Tar
rpm -ivh http://apt.sw.be/redhat/el5/en/x86_64/rpmforge/RPMS/perl-NetAddr-IP-4.027-1.el5.rf.x86_64.rpm
CentOS 5.x (i386):
rpm -ivh http://apt.sw.be/redhat/el5/en/i386/rpmforge/RPMS/perl-NetAddr-IP-4.027-1.el5.rf.i386.rpm
CentOS 4.x (x86_64):
rpm -ivh http://apt.sw.be/redhat/el4/en/x86_64/rpmforge/RPMS/perl-NetAddr-IP-4.027-1.el4.rf.x86_64.rpm
CentOS 4.x (i386):
rpm -ivh http://apt.sw.be/redhat/el4/en/i386/rpmforge/RPMS/perl-NetAddr-IP-4.027-1.el4.rf.i386.rpm
Download
http://www.ispconfig.org/ispconfig-2/download/
Forums
http://www.howtoforge.com/forums
Installation Instructions
Download the ISPConfig-2.2.36.tar.gz from ispconfig.org:
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-2.2.36.tar.gz?download
Installation on the shell as root user:
tar xvfz ISPConfig-2.2.36.tar.gz
cd install_ispconfig
./setup
The installer automatically detects the installed ISPConfig version and
performs an update.
hahni
Active Member
Diese Fehlermeldungen erhalte ich:
chmod: cannot access `./install.php': No such file or directory
./setup2: line 1090: mysql_config: No such file or directory
./setup2: line 1091: httpd: No such file or directory
./setup2: line 1092: httpd2: No such file or directory
./setup2: line 1093: httpd2: No such file or directory
./setup2: line 1103: ip_addresses: No such file or directory
./setup2: line 1105: /root/ispconfig/php/php: No such file or directory
./setup2: line 1106: /root/ispconfig/dist.info: No such file or directory
Neustart einiger Dienste...
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
httpd not running, trying to start
./setup2: line 1143: [: ==: unary operator expected
Shutting down ISPConfig system...
/etc/init.d/ispconfig_server: line 66: /root/ispconfig/httpd/bin/apachectl: No such file or directory
ISPConfig system stopped!
Starting ISPConfig system...
/etc/init.d/ispconfig_server: line 45: /root/ispconfig/httpd/bin/apachectl: No such file or directory
/etc/init.d/ispconfig_server: line 48: /root/ispconfig/php/php: No such file or directory
ISPConfig system is now up and running!
Herzlichen Glueckwunsch! Ihr ISPConfig-System ist jetzt installiert. Falls Sie Quota nachinstalliert haben, fuehren Sie noch die in der Installationsanleitung beschriebenen Schritte durch. Ansonsten ist Ihr System jetzt ohne Reboot einsatzbereit.
./setup2: line 1189: cd: /tmp/install_ispconfig/compile_aps/../..: No such file or directory
Das sieht so aus als ob Du nicht mit cd ins Install Verzeichnis gewechselt bist, bevor Du das setup gestartet hast oder es wurde sudo benutzt.
hahni
Active Member
Nein, das war auch die Meldung von 2.2.35!
Bei 2.2.36 erscheint folgendes:
make[2]: Leaving directory `/tmp/install_ispconfig/compile_aps/apache_1.3.41/src'
make[1]: Leaving directory `/tmp/install_ispconfig/compile_aps/apache_1.3.41'
make[1]: Entering directory `/tmp/install_ispconfig/compile_aps/apache_1.3.41'
===> src/support
make[2]: Entering directory `/tmp/install_ispconfig/compile_aps/apache_1.3.41/src/support'
gcc -c -I../os/unix -I../include -DLINUX=22 -DHAVE_SET_DUMPABLE -DMOD_SSL=208131 -DUSE_HSREGEX -DEAPI -DUSE_EXPAT -I../lib/expat-lite `../apaci` htpasswd.c
htpasswd.c:101: error: conflicting types for 'getline'
/usr/include/stdio.h:651: note: previous declaration of 'getline' was here
make[2]: *** [htpasswd.o] Error 1
make[2]: Leaving directory `/tmp/install_ispconfig/compile_aps/apache_1.3.41/src/support'
make[1]: *** [build-support] Error 1
make: *** [build] Error 2
ERROR: Could not make Apache
hahni
Active Member
Das hatte ich schon beim Update auf 2.2.35 geändert. Wieso war das jetzt wieder überschrieben?
fuxifux
Ich hab das Update gerade erfolgreich durchgeführt.
Seither fällt mir auf, dass ich keine als SPAM markierten Mails mehr bekomme,
dafür kommen SPAMs als normale Mails durch..
Kann ich irgendwie testen, ob Spamassassin funktioniert, oder hab ich etwas übersehn?
fuxifux
fuxifux
Der von Dir vorgeschlagene Befehl brachte:
config: no rules were found!  Do you need to run 'sa-update'?
Nach einem Aufruf von:
/home/admispconfig/ispconfig/tools/spamassassin/usr/bin/sa-update
Bleibt dann der Aufruf von:
/home/admispconfig/ispconfig/tools/spamassassin/usr/bin/spamassassin --lint
ohne Rückmeldung, was vermutlich ein gutes Zeichen ist.
Danke für den Tip!
EDIT: jetzt hab ich auch entdeckt, dass mein nach dem Y2010-Bug installierter Cron-Aufruf von sa-update auf meinem neuen Server nicht funktioniert hat.
Update auf 2.2.36 fehlgeschlagen..
Servus Forum,
ich habe soeben versucht von 2.2.35 auf 2.2.36 upzudaten - leider ohne Erfolg.
checking module dependencies and their versions...
ERROR: the required NetAddr::IP module is installed (3.14),
but is below the minimum required version 4.000,
some functionality will not be available.
  Used in determining which DNS tests are to be done for each of
  the header's received fields, and used by AWL plugin for extracting network
  address from an IPv6 addresses (and from IPv4 address on nondefault mask).
NOTE: the optional Digest::SHA module is not installed.
  The Digest::SHA module is required by the DKIM plugin.
NOTE: the optional Mail::SPF module is not installed.
  Used to check DNS Sender Policy Framework (SPF) records to fight email
  address forgery and make it easier to identify spams.
NOTE: the optional IP::Country module is not installed.
  Used by the RelayCountry plugin (not enabled by default) to determine
  the domain country codes of each relay in the path of an email.
NOTE: the optional Razor2 module is not installed,
minimum required version is 2.61.
  Used to check message signatures against Vipul's Razor collaborative
  filtering network. Razor has a large number of dependencies on CPAN
  modules. Feel free to skip installing it, if this makes you nervous;
  SpamAssassin will still work well without it.
  More info on installing and using Razor can be found
  at http://wiki.apache.org/spamassassin/InstallingRazor .
NOTE: the optional Net::Ident module is not installed.
  If you plan to use the --auth-ident option to spamd, you will need
  to install this module.
NOTE: the optional IO::Socket::INET6 module is not installed.
  This is required if the first nameserver listed in your IP
  configuration or /etc/resolv.conf file is available only via an
  IPv6 address. Also used by a DCC plugin to access dccifd over network.
NOTE: the optional IO::Socket::SSL module is not installed.
  If you wish to use SSL encryption to communicate between spamc and
  spamd (the --ssl option to spamd), you need to install this
  module. (You will need the OpenSSL libraries and use the
  ENABLE_SSL="yes" argument to Makefile.PL to build and run an SSL
  compatibile spamc.)
NOTE: the optional Mail::DKIM module is not installed,
minimum required version is 0.31, recommended version is 0.37 or higher.
  If this module is installed and the DKIM plugin is enabled,
  SpamAssassin will perform DKIM signature verification when DKIM-Signature
  header fields are present in the message headers, and check ADSP rules
  (e.g. anti-phishing) when a mail message does not contain a valid author
  domain signature. Version 0.37 or later is needed to fully support ADSP.
NOTE: the optional LWP::UserAgent module is not installed.
  The "sa-update" program requires this module to make HTTP requests.
NOTE: the optional HTTP::Date module is not installed.
  If-Modified-Since GET requests.
NOTE: the optional Encode::Detect module is not installed.
  If you plan to use the normalize_charset config setting to detect
  charsets and convert them into Unicode, you will need to install
  this module.
REQUIRED module out of date: NetAddr::IP
optional module missing: Digest::SHA
optional module missing: Mail::SPF
optional module missing: IP::Country
optional module missing: Razor2
optional module missing: Net::Ident
optional module missing: IO::Socket::INET6
optional module missing: IO::Socket::SSL
optional module missing: Mail::DKIM
optional module missing: LWP::UserAgent
optional module missing: HTTP::Date
optional module missing: Encode::Detect
warning: some functionality may not be available,
please read the above report before continuing!
make: *** No targets specified and no makefile found.  Stop.
ERROR: Could not make SpamAssassin
Natürlich bin ich jetzt Ratlos!
Bis dato haben die Updates immer hervorragend und ohne Probleme geklappt.
Was muss ich nun machen um meiner Kiste wieder Leben einzuhauchen?
lg
baerndorfer
Kann ich denn wieder auf 2.2.35 zurück updaten/downgraden wenn das Update auf 2.2.36 schief gelaufen ist?
Muss ich vorher etwas löschen?
Seit dem ich die neue IspConfig Version installiert habe wird mein AwStats nicht mehr aktualisiert. Im Cron steht alles noch drin aber eine Aktualisierung findet nicht statt. Ist da was dazu bekannt?
Danke
hahni
Active Member
Normal ist das jedenfalls nicht. Bei mir treten solche Probleme nämlich nicht auf. Welche Distribution setzt du ein?
