ISPConfig 2.2.35 is available for download.
This ISPConfig fixes a bug in the backup function and adds a fix for ClamAV on Fedora Linux.
Detailed Changelog
- Bugfix: Fixed a security problem in the ispconfig backup script. Many thanks to Quintin Russ for reporting this problem and testing the bugfix.
- Bugfix: Added a patch that fixed a compile problem in ClamAV on Fedora Linux 11 and below.
Changed system requirements
This release requires that you have sudo installed on your system.
For Debian Linux, use:
apt-get install sudo
for Fedora and Centos use:
yum install sudo
and for OpenSuSE:
yast2 -i sudo
Download
http://www.ispconfig.org/downloads.htm
Forums
http://www.howtoforge.com/forums
Installation Instructions
Download the ISPConfig-2.2.35.tar.gz from ispconfig.org:
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-2.2.35.tar.gz?download
Installation on the shell as root user:
tar xvfz ISPConfig-2.2.35.tar.gz
cd install_ispconfig
./setup
The installer automatically detects the installed ISPConfig version and
performs an update.
Detailed Changelog
yum install sudo
and for OpenSuSE:
yast2 -i sudo
Download
Forums
./setup
performs an update.
