papaminimaus
Hi,
Server: Ubuntu 10.04 mit ISPConfig 3 Perfect Setup
Imap-Login funktioniert, mails per Webmail senden auch, aber smtp-auth schlögt fehl:
/var/log/mail:
Gruß
Arne
/var/log/mail:
In der auth.log:Nov 5 13:03:16 Server postfix/smtpd[4181]: warning: SASL authentication failure: Password verification failed
Nov 5 13:03:16 Server postfix/smtpd[4181]: warning: lacal[888.888.888.888]: SASL PLAIN authentication failed: authentication failure
Nov 5 13:03:16 Server postfix/smtpd[4181]: warning:local[888.88.888.88]: SASL LOGIN authentication failed: authentication failure
main.cf:Nov 5 13:34:071 postfix/smtpd[5664]: sql_select option missing
Nov 5 13:34:07 postfix/smtpd[5664]: auxpropfunc error no mechanism available
Nov 5 13:34:07 postfix/smtpd[5664]: _sasl_plugin_load failed on sasl_auxprop_plug_init for plugin: sql
Module sind alle da, habe alle nochmal händisch nachinstalliert. Bin ratlos..# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# TLS parameters
smtpd_use_tls = yes
myhostname = hostname
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = hostname, localhost, localhost.localdomain
relayhost =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
smtpd_sasl_auth_enable = yes
smtpd_client_message_rate_limit = 100
virtual_transport = maildrop
owner_request_special = no
#smtpd_sasl_type = cyrus
message_size_limit = 0
Gruß
Arne
