Pure-FTP
griffin
ich habe seit einigen Tagen ISPC3 auf Debian 5 installiert (Standardinstallation) und es läuft so weit auch ganz gut, allerdings kann ich mir diese Logeinträge in der /var/log/messages nicht erklären.
Jul 27 19:30:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:30:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 19:35:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:35:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 19:40:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:40:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 19:45:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:45:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 19:50:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:50:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 19:55:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 19:55:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 20:00:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 20:00:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 20:05:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 20:05:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 20:10:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 20:10:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 20:15:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 20:15:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
Jul 27 20:20:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] New connection from localhost.localdomain
Jul 27 20:20:01 host1 pure-ftpd: (?@localhost.localdomain) [INFO] Logout.
hat jemand ein Idee warum hier immer versucht wird eine Verbindung aufzubauen?
Das ist der ISPConfig Monitoring Dienst, der alle 5 Minuten überprüft ob pure-ftpd auch läuft. Ist also nichts besorgniserregendes.
griffin
Dank für die schnelle Antwort!
kannst du mir evtl. auch sagen, wie ich das Intervall erhöhe? Ich vermute ja, dass ich es selbst so kurz eingestellt habe, weiß aber nicht mehr wo... :eek:
Das Intervall kann nicht geändert werden und es würde auch keinen Sinn machen, es hoch zu setzen da ansonsten der Monitor nicht mehr richtig funktionieren würde bzw. keine Sinnvollen Ergebnisse liefert.
