Probleme mit den Mailquoatas
madsam
erstmal ein Dankeschön an die ISPConfig Entwickler.
Ich habe ein größeres Problem mit dem Mailquotas.
Bei keinen Mailkonto können die quotas aktualisiert werden.
Beisp. Das Mailkonto von User web8_support wird mittles imap abgerufen.
Ausgabe repquota -avugs | grep web8:
web8_xyt -- 36 0 0 9 0 0
web8_xxxx -- 36 0 0 9 0 0
web8_xxx -- 36 0 0 9 0 0
web8_xx -- 36 0 0 9 0 0
web8_x -- 36 0 0 9 0 0
web8_abcde -- 36 0 0 9 0 0
web8_support +- 21504 20480 21504 5days 59 0 0
web8_info -- 36 0 0 9 0 0
web8_qwert -- 36 20480 21504 9 0 0
web8 -- 63592 500M 501M 4498 0 0
Ausgabe syslog:
Oct 16 12:54:10 h1032821 postfix/postdrop[3129]: warning: uid=10029: Disk quota exceeded
Oct 16 12:54:10 h1032821 postfix/sendmail[3128]: fatal: web8_support(10029): queue file write error
Oct 16 12:54:10 h1032821 postfix/smtpd[3116]: disconnect from i5387159D.versanet.de[83.135.21.157]
Oct 16 12:54:12 h1032821 postfix/local[3121]: 964A2EF8151: to=<web8_support@xxx.serverkompetenz.net>, orig_to=<fm@xxx.de>, relay=local, delay=2.
1, delays=0.17/0.01/0/1.9, dsn=5.2.0, status=bounced (can't create user output file. Command output: postdrop: warning: uid=10029: Disk quota exceeded sendma
il: fatal: web8_support(10029): queue file write error /bin/cat: write error: Disk quota exceeded procmail: Program failure (1) of "/home/admispconfig/ispcon
fig/tools/clamav/bin/clamassassin" procmail: Rescue of unfiltered data succeeded procmail: Quota exceeded while writing "/var/www/web8/user/web8_support/Mail
dir/tmp/1192532052.3122_0.xxxxxxx" )
Ausgabe mail.log:
Oct 16 12:38:10 h1032821 imapd: Failed to create cache file: maildir_lock (web8_support)
Oct 16 12:38:10 h1032821 imapd: Error: Disk quota exceeded
Oct 16 12:38:10 h1032821 imapd: Failed to create cache file: . (web8_support)
Oct 16 12:39:10 h1032821 imapd: Failed to create cache file: maildir_lock (web8_support)
Oct 16 12:39:10 h1032821 imapd: Error: Disk quota exceeded
Oct 16 12:39:10 h1032821 imapd: Failed to create cache file: . (web8_support)
Oct 16 12:40:10 h1032821 imapd: Failed to create cache file: maildir_lock (web8_support)
Oct 16 12:40:10 h1032821 imapd: Error: Disk quota exceeded
Oct 16 12:40:10 h1032821 imapd: Failed to create cache file: . (web8_support)
Ausgabe ll /var/www/www.xxx.de/user/web8_support/
insgesamt 132K
drwxr-xr-x 5 web8_support web8 4,0K 2007-10-15 12:30 .
drwxr-xr-x 11 www-data web8 4,0K 2007-10-15 12:30 ..
-rw-r--r-- 1 root root 103 2007-10-15 13:21 .antivirus.rc
-rw-r--r-- 1 root root 787 2007-10-15 13:21 .autoresponder.rc
-rw------- 1 web8_support web8 24 2007-10-15 13:21 .forward
-rw-r--r-- 1 root root 67K 2007-10-15 13:21 .html-trap.rc
-rw-r--r-- 1 root root 3,8K 2007-10-15 13:21 .local-rules.rc
drwx------ 8 web8_support web8 4,0K 2007-10-15 13:12 Maildir
-rw-r--r-- 1 root root 204 2007-10-15 13:21 .mailsize.rc
-rw-r--r-- 1 root root 465 2007-10-15 13:21 .procmailrc
-rw-r--r-- 1 root root 656 2007-10-15 13:21 .quota.rc
drwx------ 2 web8_support web8 4,0K 2007-10-15 13:56 .spamassassin
-rw-r--r-- 1 root root 1,2K 2007-10-15 13:21 .spamassassin.rc
-rw-r--r-- 1 root root 2,0K 2007-10-15 13:21 .user_prefs
-rw-r--r-- 1 root root 32 2007-10-15 13:21 .vacation.msg
drwxrwxr-x 2 web8_support web8 4,0K 2007-10-15 12:30 web
Stimmen die Rechte in diesen Verzeichnis (web8_support)?
Danke im vorraus für die Hilfe.
mfg
mad
madsam
Webquota: 500MB
Userquota Mail: 20MB
Ich habe festgestellt, dass im Verzeichnis /tmp/clamscan-xxxxx die Dateien nicht gelöscht werden.
Dadurch ist die Quota von 20 MB sehr schnell erreicht.
Ich werde clamav einzurichten.
Hat jemand ein passendes HowTo dafür?
mfg
mad
