wotan2005
Hey Folks,
über http://KUNDENDOMAIN.TLD/cgi-bin/mailman/admindb/info oder http://SERVERNAME.TLD/cgi-bin/mailman/admindb/info
kann Mailman leider nicht aufgerufen werden. Es wird mit folgender Fehlermeldung beendet:
Die Mailman.conf wie folgt eingerichtet ist:
Wo oder was ist hier der Fehler?
The requested URL /cgi-bin/mailman/admindb/info was not found on this server.
# Sample configuration for Debian mailman with Apache
# We can find mailman here:
ScriptAlias /cgi-bin/mailman/ /usr/lib/cgi-bin/mailman/
# And the public archives:
Alias /pipermail/ /var/lib/mailman/archives/public/
# Logos:
Alias /images/mailman/ /usr/share/images/mailman/
# Use this if you don't want the "cgi-bin" component in your URL:
# In case you want to access mailman through a shorter URL you should enable
# this:
#ScriptAlias /mailman/ /usr/lib/cgi-bin/mailman/
# In this case you need to set the DEFAULT_URL_PATTERN in
# /etc/mailman/mm_cfg.py to http://%s/mailman/ for the cookie
# authentication code to work. Note that you need to change the base
# URL for all the already-created lists as well.
<Directory /usr/lib/cgi-bin/mailman/>
AllowOverride None
Options ExecCGI
AddHandler cgi-script .cgi
Order allow,deny
Allow from all
</Directory>
<Directory /var/lib/mailman/archives/public/>
Options FollowSymlinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory /usr/share/images/mailman/>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
## The following describes how to configure mailman on
## a dedicated virtual host, courtesy Marco d'Itri.
# Add these lines in /etc/mailman/mm_cfg.py:
#DEFAULT_EMAIL_HOST = 'lists.example.net'
#DEFAULT_URL_HOST = 'lists.example.net'
#DEFAULT_URL_PATTERN = 'http://%s/'
#<VirtualHost *>
#ServerName lists.example.net
#DocumentRoot /var/www/lists
#ErrorLog /var/log/apache2/lists-error.log
#CustomLog /var/log/apache2/lists-access.log combined
#<Directory /var/lib/mailman/archives/>
# Options FollowSymLinks
# AllowOverride None
#</Directory>
#Alias /pipermail/ /var/lib/mailman/archives/public/
#Alias /images/mailman/ /usr/share/images/mailman/
#ScriptAlias /admin /usr/lib/cgi-bin/mailman/admin
#ScriptAlias /admindb /usr/lib/cgi-bin/mailman/admindb
#ScriptAlias /confirm /usr/lib/cgi-bin/mailman/confirm
#ScriptAlias /create /usr/lib/cgi-bin/mailman/create
#ScriptAlias /edithtml /usr/lib/cgi-bin/mailman/edithtml
#ScriptAlias /listinfo /usr/lib/cgi-bin/mailman/listinfo
#ScriptAlias /options /usr/lib/cgi-bin/mailman/options
#ScriptAlias /private /usr/lib/cgi-bin/mailman/private
#ScriptAlias /rmlist /usr/lib/cgi-bin/mailman/rmlist
#ScriptAlias /roster /usr/lib/cgi-bin/mailman/roster
#ScriptAlias /subscribe /usr/lib/cgi-bin/mailman/subscribe
#</VirtualHost>
