[Thu Sep 14 15:28:10.162336 2023] [proxy:error] [pid 909582] (111)Connection refused: AH00957: FCGI: attempt to connect to 127.0.0.1:24475 (*:80) failed
[Thu Sep 14 15:28:10.162392 2023] [proxy_fcgi:error] [pid 909582] [client x.x.x.x:43225] AH01079: failed to make connection to backend: 127.0.0.1
Und bekomme wenn ich die Webseite aufrufe einen Error 503
Ideen ?
Frage mich gerade warum der auf 80 connecten will....service php8.2-fpm status
● php8.2-fpm.service - The PHP 8.2 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php8.2-fpm.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-09-14 15:27:40 CEST; 3min 36s ago
Docs: manhp-fpm8.2(8)
Process: 909579 ExecStartPost=/usr/lib/php/php-fpm-socket-helper install /run/php/php-fpm.sock /etc/php/8.2/fpm/pool.d/www.conf 82 (code=exited, status=0/SUCCESS)
Main PID: 909514 (php-fpm8.2)
Status: "Processes active: 0, idle: 64, Requests: 0, slow: 0, Traffic: 0req/sec"
Tasks: 65 (limit: 9464)
Memory: 57.0M
CPU: 297ms
CGroup: /system.slice/php8.2-fpm.service
├─909514 "php-fpm: master process (/etc/php/8.2/fpm/php-fpm.conf)"
Ideen ?
