Halllo Leute ich brauche dringent eure hilfe.
Ich kriege einfach Squirrelmail nicht zum laufen.
HAbe alles so installiert wie in einer Website beschrieben bin jetzt aber irgendwie ratlos..
Wenn ich eine Email schicken will kommt dieser fehler :
Message not sent. Server replied:
so das ist die main.cf
Connection refused
111 Can't open SMTP stream.
jetzt die mail.log 111 Can't open SMTP stream.
und jetzt die mail.errNov 28 18:34:59 NbI-791 postfix/error[28455]: CDDA565A1A10: to=<www-data@leonard_d20@yahoo.com>, orig_to=<www-data>, relay=none, delay=21295, delays=21294/1/0/0.09, dsn=4.4.2, status=deferred (delivery temporarily suspended: lost connection with 127.0.0.1[127.0.0.1] while receiving the initial server greeting)
Nov 28 18:34:59 NbI-791 postfix/error[28427]: E23B665A1A03: to=<www-data@leonard_d20@yahoo.com>, orig_to=<www-data>, relay=none, delay=41096, delays=41093/2.8/0/0.28, dsn=4.4.2, status=deferred (delivery temporarily suspended: lost connection with 127.0.0.1[127.0.0.1] while receiving the initial server greeting)
Nov 28 18:34:59 NbI-791 postfix/error[28428]: 0DDBB65A1A00: to=<www-data@leonard_d20@yahoo.com>, orig_to=<www-data>, relay=none, delay=12897, delays=12893/3.5/0/0.28, dsn=4.4.2, status=deferred (delivery temporarily suspended: lost connection with 127.0.0.1[127.0.0.1] while receiving the initial server greeting)
Nov 28 18:34:59 NbI-791 postfix/error[28443]: DE69665A1A09: to=<www-data@leonard_d20@yahoo.com>, orig_to=<www-data>, relay=none, delay=296, delays=294/2/0/0.21, dsn=4.4.2, status=deferred (delivery temporarily suspended: lost connection with 127.0.0.1[127.0.0.1] while receiving the initial server greeting)
Nov 28 18:34:59 NbI-791 postfix/error[28464]: BABE565A1A08: to=<www-data@leonard_d20@yahoo.com>, orig_to=<www-data>, relay=none, delay=34495, delays=34493/2/0/0.21, dsn=4.4.2, status=deferred (delivery temporarily suspended: lost connection with 127.0.0.1[127.0.0.1] while receiving the initial server greeting)
Nov 28 05:47:23 NbI-791 postfix/master[4503]: fatal: bind 0.0.0.0 port 25: Address already in use
Nov 28 06:50:49 NbI-791 postfix/master[28908]: fatal: bind 0.0.0.0 port 25: Address already in use
Nov 28 07:13:29 NbI-791 postfix/master[30764]: fatal: bind 0.0.0.0 port 25: Address already in use
Nov 28 18:32:44 NbI-791 postfix/postfix-script[28286]: error: unknown command: 'restart'
Nov 28 18:32:44 NbI-791 postfix/postfix-script[28287]: fatal: usage: postfix start (or stop, reload, abort, flush, check, status, set-permissions, upgrade-configuration)
Nov 28 18:32:57 NbI-791 postfix/postfix-script[28294]: fatal: the Postfix mail system is not running
Nov 28 18:34:21 NbI-791 postfix/postfix-script[28317]: fatal: the Postfix mail system is not running
Nov 28 18:44:36 NbI-791 amavis[29783]: (29783-05-10) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:37 NbI-791 amavis[29782]: (29782-05-12) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:39 NbI-791 amavis[29782]: (29782-05-15) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:40 NbI-791 amavis[29782]: (29782-05-16) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:41 NbI-791 amavis[29783]: (29783-05-19) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:41 NbI-791 amavis[29782]: (29782-05-21) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:42 NbI-791 amavis[29782]: (29782-05-22) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:42 NbI-791 amavis[29783]: (29783-05-22) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:45 NbI-791 amavis[29783]: (29783-05-23) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:46 NbI-791 amavis[29782]: (29782-05-26) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:46 NbI-791 amavis[29782]: (29782-05-27) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:47 NbI-791 amavis[29782]: (29782-05-28) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:47 NbI-791 amavis[29782]: (29782-05-29) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:47 NbI-791 amavis[29783]: (29783-05-29) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:47 NbI-791 amavis[29782]: (29782-05-31) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:48 NbI-791 amavis[29783]: (29783-05-31) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:49 NbI-791 amavis[29782]: (29782-05-33) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:51 NbI-791 amavis[29782]: (29782-05-34) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:52 NbI-791 amavis[29782]: (29782-05-35) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
Nov 28 18:44:52 NbI-791 amavis[29783]: (29783-05-36) (!!)file(1) utility (/usr/bin/file) FAILED: run_command: can't fork: Cannot allocate memory at /usr/sbin/amavisd-new line 3077.
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# TLS parameters
smtpd_use_tls = yes
myhostname = NbI-791.NbIServ.com
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = NbI-791.NbIServ.com, localhost, localhost.localdomain
relayhost =
mailbox_command =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
inet_protocols = all
smtpd_sasl_auth_enable = yes
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
smtpd_client_message_rate_limit = 100
virtual_transport = maildrop
owner_request_special = no
