was da falsch weiß ich nicht, habe nichts geändert.auto eth0
iface eth0 inet static
address 46.4.103.179
broadcast 46.4.103.191
netmask 255.255.255.224
gateway 46.4.103.161
up route add -net 46.4.103.160 netmask 255.255.255.224 gw 46.4.103.161 eth0
auto eth1
iface eth1 inet static
address 46.4.103.183
broadcast 46.1.103.191
Kein Fehler.[ 9.636216] EXT3 FS on sda2, internal journal
[ 9.636221] EXT3-fs: mounted filesystem with ordered data mode.
[ 11.175272] eth0: Using EEPROM-set media 100baseTx-FDX.
[ 12.506414] eth1: Using EEPROM-set media 100baseTx-FDX.
[ 21.180065] eth0: no IPv6 routers present
[ 23.348169] eth1: no IPv6 routers present
[ 415.920032] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 497.669343] eth0: Using EEPROM-set media 100baseTx-FDX.
[ 497.851233] eth1: Using EEPROM-set media 100baseTx-FDX.
[ 508.172100] eth0: no IPv6 routers present
[ 508.432200] eth1: no IPv6 routers present
[ 533.290335] eth0: Using EEPROM-set media 100baseTx-FDX.
[ 533.437488] eth1: Using EEPROM-set media 100baseTx-FDX.
[ 544.072026] eth0: no IPv6 routers present
[ 544.160091] eth1: no IPv6 routers present
Running /etc/init.d/networking restart is deprecated because it may not enable again some interfaces ... (warning).
Reconfiguring network interfaces...done.
Diesen Teil zum Beispiel.up route add -net 46.4.103.160 netmask 255.255.255.224 gw 46.4.103.161 eth0
Er sagt SIOCADDRT: File exists. Failed to bring up etho0
server1:~# iptables -L
Chain INPUT (policy DROP)
target prot opt source destination
fail2ban-ssh tcp -- anywhere anywhere multiport dports ssh
DROP tcp -- anywhere loopback/8
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
DROP all -- 224.0.0.0/4 anywhere
PUB_IN all -- anywhere anywhere
DROP all -- anywhere anywhere
Chain FORWARD (policy DROP)
Chain OUTPUT (policy ACCEPT)
PUB_OUT all -- anywhere anywhere
Chain INT_IN (0 references)
ACCEPT icmp -- anywhere anywhere
Chain INT_OUT (0 references)
Chain PAROLE (12 references)
Chain PUB_IN (5 references)
ACCEPT icmp -- anywhere anywhere icmp destination-unreachable
ACCEPT icmp -- anywhere anywhere icmp echo-reply
ACCEPT icmp -- anywhere anywhere icmp time-exceeded
ACCEPT icmp -- anywhere anywhere icmp echo-request
PAROLE tcp -- anywhere anywhere tcp dpt:ftp-data
PAROLE tcp -- anywhere anywhere tcp dpt:ssh
PAROLE tcp -- anywhere anywhere tcp dpt:smtp
PAROLE tcp -- anywhere anywhere tcp dpt:domain
PAROLE tcp -- anywhere anywhere tcp dpt:www
PAROLE tcp -- anywhere anywhere tcp dptop3
PAROLE tcp -- anywhere anywhere tcp dpt:imap2
PAROLE tcp -- anywhere anywhere tcp dpt:https
PAROLE tcp -- anywhere anywhere tcp dpt:mysql
PAROLE tcp -- anywhere anywhere tcp dpt:http-alt
PAROLE tcp -- anywhere anywhere tcp dpt:webmin
ACCEPT udp -- anywhere anywhere udp dpt:domain
ACCEPT udp -- anywhere anywhere udp dpt:mysql
DROP icmp -- anywhere anywhere
Chain PUB_OUT (5 references)
Chain fail2ban-ssh (1 references)
RETURN all -- anywhere anywhere
