Oct 25 20:10:02 server /USR/SBIN/CRON[2037]: (www-data) CMD ([ -x /usr/share/awstats/tools/update.sh ] && /usr/share/awstats/tools/update.sh)
Oct 25 20:10:02 server /USR/SBIN/CRON[2038]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:10:02 server /USR/SBIN/CRON[2039]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:10:02 server pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Oct 25 20:10:02 server pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Oct 25 20:10:02 server dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Oct 25 20:10:02 server dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Oct 25 20:10:02 server postfix/smtpd[2068]: connect from localhost.localdomain[127.0.0.1]
Oct 25 20:10:02 server postfix/smtpd[2068]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Oct 25 20:10:02 server postfix/smtpd[2068]: disconnect from localhost.localdomain[127.0.0.1]
Oct 25 20:10:03 server postfix/pickup[1900]: 788752B83F8: uid=33 from=<www-data>
Oct 25 20:10:03 server postfix/cleanup[2088]: 788752B83F8: message-id=<20111025181003.788752B83F8@Server.fritz.box>
Oct 25 20:10:03 server postfix/qmgr[1901]: 788752B83F8: from=<www-data@Server.fritz.box>, size=858, nrcpt=1 (queue active)
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'server.fritz.box/MX/IN': 2001:500:3::42#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'update.sh.dbl.spamhaus.org/A/IN': 2001:7b8:3:1f:0:2:53:2#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'ns1.zurich.surf.net/AAAA/IN': 2001:630:0:8::14#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'ns1.zurich.surf.net/AAAA/IN': 2001:620:0:9::1103#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'ns1.zurich.surf.net/AAAA/IN': 2001:630:0:9::14#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'server.fritz.box.rhsbl.ahbl.org/A/IN': 2a00:f10:111::1337:1001#53
Oct 25 20:10:03 server named[976]: error (network unreachable) resolving 'server.fritz.box.rhsbl.ahbl.org/A/IN': 2620:64:0:1::6#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'ns1.surfnet.nl/AAAA/IN': 2001:610:3:200a:192:87:36:2#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'ns3.xs4all.nl/AAAA/IN': 2001:888:0:7::77#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'ns3.surfnet.nl/A/IN': 2001:610:1:800a:192:87:106:101#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'rbldnsd.a.rbl-auth.sr.sonic.net/AAAA/IN': 2001:5a8:0:3::1#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'rbldnsd.b.rbl-auth.sr.sonic.net/A/IN': 2607:f0d0:1102:f::2#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'rbldnsd.a.rbl-auth.sr.sonic.net/A/IN': 2001:48c8:1:1::2#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'rfci.bl.xs4all.nl/A/IN': 2001:888:0:8::88#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'rfci.bl.xs4all.nl/AAAA/IN': 2001:888:0:8::88#53
Oct 25 20:10:04 server named[976]: error (network unreachable) resolving 'ns2.surfnet.nl/A/IN': 2001:610:1:800a:192:87:106:101#53
Oct 25 20:10:05 server postfix/smtpd[2093]: connect from localhost.localdomain[127.0.0.1]
Oct 25 20:10:05 server postfix/smtpd[2093]: 6FAE32B83F7: client=localhost.localdomain[127.0.0.1]
Oct 25 20:10:05 server postfix/cleanup[2088]: 6FAE32B83F7: message-id=<20111025181003.788752B83F8@Server.fritz.box>
Oct 25 20:10:05 server postfix/qmgr[1901]: 6FAE32B83F7: from=<www-data@Server.fritz.box>, size=1331, nrcpt=1 (queue active)
Oct 25 20:10:05 server amavis[1371]: (01371-01) Passed CLEAN, <www-data@Server.fritz.box> -> <www-data@Server.fritz.box>, Message-ID: <20111025181003.788752B83F8@Server.fritz.box>, mail_id: SKbcvmvangbv, Hits: 1.178, size: 858, queued_as: 6FAE32B83F7, 1913 ms
Oct 25 20:10:05 server postfix/smtp[2090]: 788752B83F8: to=<www-data@Server.fritz.box>, orig_to=<www-data>, relay=127.0.0.1[127.0.0.1]:10024, delay=2.1, delays=0.12/0.01/0.01/1.9, dsn=2.0.0, status=sent (250 2.0.0 Ok, id=01371-01, from MTA([127.0.0.1]:10025): 250 2.0.0 Ok: queued as 6FAE32B83F7)
Oct 25 20:10:05 server postfix/qmgr[1901]: 788752B83F8: removed
Oct 25 20:10:05 server postfix/local[2097]: 6FAE32B83F7: to=<www-data@Server.fritz.box>, relay=local, delay=0.16, delays=0.04/0.05/0/0.07, dsn=2.0.0, status=sent (delivered to command: procmail -a "$EXTENSION")
Oct 25 20:10:05 server postfix/qmgr[1901]: 6FAE32B83F7: removed
Oct 25 20:11:01 server /USR/SBIN/CRON[2100]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:12:01 server /USR/SBIN/CRON[2109]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:13:01 server /USR/SBIN/CRON[2117]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:14:01 server /USR/SBIN/CRON[2128]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:15:01 server /USR/SBIN/CRON[2137]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:15:01 server /USR/SBIN/CRON[2138]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
Oct 25 20:15:02 server pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Oct 25 20:15:02 server pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Oct 25 20:15:02 server dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Oct 25 20:15:02 server dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Oct 25 20:15:02 server postfix/smtpd[2161]: connect from localhost.localdomain[127.0.0.1]
Oct 25 20:15:02 server postfix/smtpd[2161]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Oct 25 20:15:02 server postfix/smtpd[2161]: disconnect from localhost.localdomain[127.0.0.1]
Oct 25 20:15:05 server postfix/smtpd[2093]: timeout after END-OF-MESSAGE from localhost.localdomain[127.0.0.1]
Oct 25 20:15:05 server postfix/smtpd[2093]: disconnect from localhost.localdomain[127.0.0.1]
Oct 25 20:16:01 server /USR/SBIN/CRON[2181]: (root) CMD (/usr/local/ispconfig/server/server.sh > /dev/null 2>> /var/log/ispconfig/cron.log)
