ISPConfig 3.0.5.4 Patch 5 released
What's new in ISPConfig 3.0.5.4p5
This release introduces support for Ubuntu 14.10 and fixes some Bugs.
See changelog link below for a list of all changes that are included in this release.
- Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.5.4p5.tar.gz
- Changelog
http://bugtracker.ispconfig.org/index.php?do=index&tasks=&project=3&due=83&status[]=
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Wheezy (7.0) and Debian testing
- Ubuntu 7.10 - 14.10
- OpenSuSE 11 - 13.1
- CentOS 5.2 - 7
- Fedora 9 - 15
- Installation
http://www.ispconfig.org/ispconfig-3/documentation/
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
http://www.faqforge.com/linux/controlpanels/ispconfig3/how-to-update-ispconfig-3/
- Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
wlbi
Hi, I just tried to update. When I enter the update command in the shell it shows the following output with a lot of errors.
See paste here: http://paste.ubuntu.com/8722227/
I don't like to select the update method, because of the previous errors.
Do you know what's wrong? It's an Ubuntu 14.04 server
Or can I continue the update without crashing the installation?
Alex
Das hat nichts mit dem ispconfig zu tun sondern ist ein fehler des php snmp modules. Einfach php5-snmp deinstallieren.
wlbi
pkg -l | grep php5
libapache2-mod-php5  5.5.9+dfsg-1ubuntu4.4  amd64  server-side, HTML-embedded scripting language (Apache 2 module)
php5  5.5.9+dfsg-1ubuntu4.4  all  server-side, HTML-embedded scripting language (metapackage)
php5-cli  5.5.9+dfsg-1ubuntu4.4  amd64  command-line interpreter for the php5 scripting language
php5-common  5.5.9+dfsg-1ubuntu4.4  amd64  Common files for packages built from the php5 source
php5-json  1.3.2-2build1  amd64  JSON module for php5
php5-readline  5.5.9+dfsg-1ubuntu4.4  amd64  Readline module for php5
dpkg -l | grep snmp
libsnmp-base         5.7.2~dfsg-8.1ubuntu3   all          SNMP configuration script, MIBs and documentation
libsnmp30:amd64   5.7.2~dfsg-8.1ubuntu3  amd64   SNMP (Simple Network Management Protocol) library
Was sollte ich da deinstallieren?
Seit der Installation von ISPConfig habe ich aber nichts deinstalliert.
Alfredus
Update lief problemlos durch, aber:
bei Webseiten->Speicherplatzbeschränkung wird nichts mehr angezeigt
im Dashborad allerdings schon.
Da wurde nichts am betreffenden Code geändert. Ich habe gerade mal hier auf meinem Debian System nachgesehen, der Speicher wird richtig angezeigt.
Alfredus
bei mir nicht, bin immer noch am suchen.
Weiss aber genau, das das vor dem Update noch ging.
Weiter ist mir noch aufgefallen, das unter System->Ispconfiguser->Gruppen
ein Auswahlmenü mit den Gruppen zwar da ist, aber dort die Namen der User drin sind.
Ebenso die Radiobuttons darunter (nur die Namen)
Denke mal nicht das das so sein soll, oder?
Das ist richtig, denn es geht hier nicht um User sondern um Gruppen und der name der Gruppen entspricht ja den usernamen eines Kunden, denn jeder Kunde hat ja eine Gruppe. Das erste Feld legt die primäre Gruppe fest und die Liste darunter sind optionale Zusatzgruppen.
Siehe warnung über der liste, alle manuellen änderungen die du dort mahst werden höchst wahrscheinlich zu fehlfunktionen führen.
Alfredus
mir ging es ja nur ums Prinzip :)
Ausserdem wäre mir das Problem mit der Speicherplatzbeschränkung wichtiger.
Was ich bis jetzt gefunden habe:
/usr/local/ispconfig/interface/web/sites/user_quota_stats.php
PHP:
// $tmp_rec = $app->db->queryOneRecord("SELECT data from monitor_data WHERE type = 'harddisk_quota' ORDER BY created DESC");
// $monitor_data = unserialize($app->db->unquote($tmp_rec['data']));
einkommentiert und
PHP:
$tmp_rec =  $app->db->queryAllRecords("SELECT data from monitor_data WHERE type = 'harddisk_quota' ORDER BY created DESC");
$monitor_data = array();
if(is_array($tmp_rec)) {
    foreach ($tmp_rec as $tmp_mon) {
        $monitor_data = array_merge_recursive($monitor_data, unserialize($app->db->unquote($tmp_mon['data'])));
auskommentiert
bringt mir die Anzeige wieder, aber ich denke mal das wird ja nicht ohne Grund so geändert sein, zumal die Anzeige auf entfernten Server nicht stimmt.
Ich habe gestern noch diverse Kundensysteme aktualisiert, quota anzeige geht auf allen. Der Code den Du da zitiert hast wurde irgendwann in 2013 geändert, war also schon in den ganzen letzten Releases so. Er ist notwendig damit quota auch funktioniert wenn bei mehr als einer Partition des Servers quota aktiv ist.
Alfredus
Quota anisch funktioniert, nur das anzeigen eben nicht.
Bin aber auch nicht fündig geworden :)
Hab mal die Files vorher nachher verglichen, alles gleich, nur warum zeigts nix mehr an?
Kann man das speichern in der DB auch irgendwie manuell anstossen? Dann würde ich die Eintraäge in der log-Tabelle mal löschen
Alfredus
Habs gefunden :)
Lag doch am Update vom mysql, dort wurde wieder eine neue my.cnf geschrieben (warum auch immer)
Dadurch konnte der Master-Server nicht mehr kommunizieren, da mysql wieder an 127.0.0.1 gebunden war.
Hab das korrigiert und schon war die Anzeige wieder da :)
Da sucht man fast 2 Tage und die Lösung ist doch so simpel :)
robotto7831a
Active Member
Bei zwei Updates ist mir schon folgendes aufgefallen.
Wenn ich ispconfig_update starte, dann lädt der die aktuelle Version runter entpackt das tar und dann hängt er augenscheinlich. Wenn ich dann Enter drücke, dann geht es weiter. Danach sieht man erst, dass er bei der Frage nach dem Backup stand und auf Antwort gewartet hat.
Auf dem Bildschirm sieht man aber vorher nur das Dateien entpackt werden und dann ist der letzte Dateiname auf dem Bildschirm in der Mitte abgeschnitten und er hängt.
System Debian 7
