ISPConfig 3.0.1 is available for download. This release is the first stable release of the ISPConfig 3 series.
ISPConfig 3 is a new Hosting Control Panel rewritten from scratch. ISPConfig 3 is not a direct update for ISPConfig 2. Do not install it on an ISPConfig 2 server. The development of ISPConfig 2 will not stop with the release of ISPConfig 3.
Features of ISPConfig 3 compared to ISPConfig 2
- Support for virtual mail users
- Support for virtual FTP users
- Support for multiple servers
- Support for splitting of services to multiple servers (database, web, FTP and DNS can be on different servers).
Download
The software itself can be downloaded here:
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.1.tar.gz?use_mirror=
Changes:
- Many bugs have been fixed, see bugtracker:
http://bugtracker.ispconfig.org/index.php?string=&project=3&due[]=19&status[]=closed&do=index
For a detailed changelog, please have a look at the SVN history with an SVN client of your choice:
svn://svn.ispconfig.org/ispconfig3/trunk/
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Debian Lenny (5.0)
- Ubuntu 7.10 - 8.10
- OpenSuSE 11 - 11.1
- CentOS 5.2
- Fedora 9
Installation
The installation instructions for ISPConfig can be found in the text files (named INSTALL_*.txt) which are inside the docs folder of the ISPConfig-3.0.1.tar.gz file.
Update
ispconfig_update.sh
The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
Download
Changes:
Known Issues:
BUG Reporting
- CentOS 5.2
- Fedora 9
Installation
Update
ispconfig_update.sh
cd /tmp
php -q update.php
