Fehler Webverzeichnis
redi78
Hallo Leute,
irgendwie sehe ich bei einem Webverzeichnis (User) mehr Verzeichnisse als bei allen anderen. Habt ihr eine Erklärung dazu?
lg redi78
redi78
Mhh kann das etwas mit diesen Fehlermeldungen zu tun haben?
chmod: cannot access `/var/www/clients/client1/web10/*': No such file or directory
chmod: cannot access `/var/www/clients/client1/web12/*': No such file or directory
chmod: cannot access `/var/www/clients/client1/web9/*': No such file or directory
Warning: Truncating oversized referrer field [239]
chmod: cannot access `/var/www/clients/client1/web20/*': No such file or directory
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/Release.gpg Could not connect to security.ubuntu.com:80 (91.189.88.37), connection timed out
W: Some index files failed to download, they have been ignored, or old ones used instead.
W: You may want to run apt-get update to correct these problems
Warning: Truncating oversized referrer field [411]
Warning: Truncating oversized request field
Skipping bad record (692)
Skipping bad record (91)
Skipping bad record (72)
Skipping bad record (98)
mkdir: cannot create directory `/var/www/clients/client1/web10/var': File exists
mkdir: cannot create directory `/var/www/clients/client1/web10/var/run': File exists
ln: creating hard link `/var/www/clients/client1/web10/var/run/mysqld/mysqld.sock' => `/var/run/mysqld/mysqld.sock': Invalid cross-device link
ERROR: /usr/share/php does not exist
Warning: Truncating oversized request field [271]
chmod: cannot access `/var/www/clients/client1/web13/*': No such file or directory
chroot: cannot run command `userdel': No such file or directory
chmod: cannot access `/var/www/clients/client1/web21/*': No such file or directory
Warning: Truncating oversized referrer field [302]
chmod: cannot access `/var/www/clients/client1/web22/*': No such file or directory
SIOCDELRT: No such process
SIOCADDRT: No such process
SIOCSIFFLAGS: Cannot assign requested address
W: Failed to fetch http://packages.medibuntu.org/dists/hardy/Release.gpg Could not connect to packages.medibuntu.org:80 (87.98.138.11), connection timed out [IP: 87.98.138.11 80]
Da scheinen ein paar Verzeichnisse zu fehlen. Welche ISPConfig Version setzt Du ein und hast Du irgend was in
/var/www/clients/client1/ manuell gelöscht?
Ok. Geht denn irgend was bestimmtes nicht? Die ursprüngliche Frage wurde ja bereits von burge beantwortet und die Fehler im cron log können auch schon älter sein.
redi78
Hier das sind die aktuelle Fehler im Cron Log. Wie kann ich diese beheben?
Was bedeutet SIOCADDRT: No such Process?
Welche Repositories sollen den für ein Hardy Heron System eingetragen sein. Denn ich denke dehalb erhalte ich im Cron Log diese Fehlermeldungen:
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/Release.gpg Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/Release.gpg Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/Release.gpg Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://packages.medibuntu.org/dists/hardy/Release.gpg Cannot initiate the connection to packages.medibuntu.org:80 (88.191.82.11). - connect (101 Network is unreachable) [IP: 88.191.82.11 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/main/binary-i386/Packages.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/restricted/binary-i386/Packages.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/main/source/Sources.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/restricted/source/Sources.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/universe/binary-i386/Packages.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/universe/source/Sources.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/multiverse/binary-i386/Packages.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/hardy-security/multiverse/source/Sources.gz Cannot initiate the connection to security.ubuntu.com:80 (91.189.88.37). - connect (101 Network is unreachable)
W: Failed to fetch http://packages.medibuntu.org/dists/hardy/free/binary-i386/Packages.gz Cannot initiate the connection to packages.medibuntu.org:80 (88.191.82.11). - connect (101 Network is unreachable) [IP: 88.191.82.11 80]
W: Failed to fetch http://packages.medibuntu.org/dists/hardy/non-free/binary-i386/Packages.gz Cannot initiate the connection to packages.medibuntu.org:80 (88.191.82.11). - connect (101 Network is unreachable) [IP: 88.191.82.11 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/main/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/restricted/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/main/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/restricted/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/universe/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/universe/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/multiverse/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy/multiverse/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/main/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/restricted/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/main/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/restricted/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/universe/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/universe/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/multiverse/binary-i386/Packages.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
W: Failed to fetch http://at.archive.ubuntu.com/ubuntu/dists/hardy-updates/multiverse/source/Sources.gz Cannot initiate the connection to at.archive.ubuntu.com:80 (91.189.88.45). - connect (101 Network is unreachable) [IP: 91.189.88.45 80]
E: Some index files failed to download, they have been ignored, or old ones used instead.
Im Prinzip funktioniert sonst alles. Aber wie kann ich bei diesem einen Web die Verzeichnisse wieder verstecken. Was genau muss ich da auf der Shell machen?
Danke schon im Voraus und lg aus Wien,
redi78
redi78
Kann das damit zusammenhängen? Ich hab in der passwd folgendes bei web10 stehen:
web9:x:5008:5004::/var/www/clients/client1/web9:/bin/false
web10:x:5009:5004::/var/www/clients/client1/web10/./home/web10:/usr/sbin/jk_chr$
web12:x:5011:5004::/var/www/clients/client1/web12:/bin/false
web14:x:5013:5004::/var/www/clients/client1/web14:/bin/false
bei den anderen nicht. Soll ich das abändern bzw. wie? Einfach umschreiben?
lg redi78
Burge
entziehe dem kunden shell zugriff und schalte jailkit hab in den web/benutzer einstellungen.
Nix von hand darin rum wuschteln hat doch ein grund warum es da steht und den Grund hatte ich dir doch auch schon geschrieben.
redi78
Hab ich das jetzt richtig gemacht? Denn ich hab das noch immer so drinnen stehen.
lg redi78
Burge
die einstellungen sind ok, in wie fern ispconfig die eintraege aus der passwd entfernt und die gejailkiteten verzeichnisse dann wieder loescht muss Till mal was sagen. Moeglicherweise ist der Part noch nicht 100% fertig aber schaun wir mal was er sagt.
redi78
Ah ok...gg ja das hat sich jetzt erledigt. Es funktiniert jetzt auch der Cron so wie es sein soll...
nur fehlt halt noch die Änderung von ISPC in passwd.
