Welches OS könnte ich anstelle von Debian lenny und Etch nehmen? (leider sind beide fehlerhaft).
Beide setups laufen perfekt auf zig tausenden von Servern weltweit, wie burge gesagt hat ist es das einfachste setup und die beste Wahl für ISPConfig.
... Daher die Frage bei welchem Anbieter du bist.
Jan 8 12:53:20 whv-server1 postfix/smtpd[7363]: connect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:20 whv-server1 postfix/policyd-weight[7366]: decided action=PREPEND X-policyd-weight: using cached result; rate: -8.5; <client=83.151.25.206> <h$
Jan 8 12:53:20 whv-server1 postgrey[7378]: action=greylist, reason=early-retry (10s missing), client_name=srv052.fs-itsolutions.de, client_address=83.151.25$
Jan 8 12:53:20 whv-server1 postfix/smtpd[7363]: NOQUEUE: reject: RCPT from srv052.fs-itsolutions.de[83.151.25.206]: 450 4.2.0 <info@bormen-plockern.com>: Re$
Jan 8 12:53:21 whv-server1 postfix/smtpd[7363]: disconnect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:22 whv-server1 postfix/smtpd[7364]: connect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:22 whv-server1 postfix/policyd-weight[17031]: decided action=PREPEND X-policyd-weight: using cached result; rate: -8.5; <client=83.151.25.206> <$
Jan 8 12:53:22 whv-server1 postgrey[7378]: action=greylist, reason=early-retry (8s missing), client_name=srv052.fs-itsolutions.de, client_address=83.151.25.$
Jan 8 12:53:22 whv-server1 postfix/smtpd[7364]: NOQUEUE: reject: RCPT from srv052.fs-itsolutions.de[83.151.25.206]: 450 4.2.0 <info@bormen-plockern.com>: Re$
Jan 8 12:53:22 whv-server1 postfix/smtpd[7364]: disconnect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:24 whv-server1 postfix/smtpd[7355]: connect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:24 whv-server1 postfix/policyd-weight[17031]: decided action=PREPEND X-policyd-weight: using cached result; rate: -8.5; <client=83.151.25.206> <$
Jan 8 12:53:24 whv-server1 postgrey[7378]: action=greylist, reason=early-retry (6s missing), client_name=srv052.fs-itsolutions.de, client_address=83.151.25.$
Jan 8 12:53:24 whv-server1 postfix/smtpd[7355]: NOQUEUE: reject: RCPT from srv052.fs-itsolutions.de[83.151.25.206]: 450 4.2.0 <info@bormen-plockern.com>: Re$
Jan 8 12:53:24 whv-server1 postfix/smtpd[7355]: disconnect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:48 whv-server1 postfix/smtpd[7363]: connect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:48 whv-server1 postfix/policyd-weight[7366]: decided action=PREPEND X-policyd-weight: using cached result; rate: -8.5; <client=83.151.25.206> <h$
Jan 8 12:53:48 whv-server1 postgrey[7378]: action=pass, reason=triplet found, delay=611, client_name=srv052.fs-itsolutions.de, client_address=83.151.25.206,$
Jan 8 12:53:48 whv-server1 postfix/smtpd[7363]: B81B4E6070C: client=srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:48 whv-server1 postfix/cleanup[7380]: B81B4E6070C: message-id=<4B472AD6.1060108@leobo.de>
Jan 8 12:53:48 whv-server1 postfix/qmgr[7120]: B81B4E6070C: from=<joshua.brueck@leobo.de>, size=1789, nrcpt=1 (queue active)
Jan 8 12:53:48 whv-server1 postfix/smtpd[7363]: disconnect from srv052.fs-itsolutions.de[83.151.25.206]
Jan 8 12:53:48 whv-server1 postfix/virtual[7382]: fatal: open database /etc/postfix/ispcp/mailboxes.db: Permission denied
Jan 8 12:53:49 whv-server1 postfix/master[7115]: warning: process /usr/lib/postfix/virtual pid 7382 exit status 1
Jan 8 12:53:49 whv-server1 postfix/master[7115]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
