wenn ich wüsste wie das geht wäre das auch viel einfacher.
Die Fehlermeldung kommt, wenn ich smtp_bind_address festlege - und Mails gehen nicht mehr raus.
Meine main.cf sieht so aus:
#Eingetragen für Sicherheit
smtpd_banner = $myhostname ESMTP
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = server.sportwebspace.at, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8
#mynetworks = 127.0.0.0/8 [::1]/128
inet_interfaces = all
recipient_delimiter = +
#Damit wird nur von dieser IP gesendet!!
smtp_bind_address = IP.IP.IP.IP
myorigin = /etc/mailname
mailbox_size_limit = 0
inet_protocols = all
myhostname = server.sportwebspace.at
virtual_alias_domains =
virtual_alias_maps = hash:/var/lib/mailman/data/virtual-mailman, proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_uid_maps = mysql:/etc/postfix/mysql-virtual_uids.cf
virtual_gid_maps = mysql:/etc/postfix/mysql-virtual_gids.cf
smtpd_sasl_auth_enable = yes
#Eingetragen für weniger SPAM
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, reject_rbl_client ix.dnsbl.manitu.net, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client dul.dnsbl.sorbs.net, reject_rbl_client bl.spamcop.net, reject_rbl_client psbl.surriel.com, reject_rbl_client noptr.spamrats.com
smtpd_use_tls = yes
smtpd_tls_CAfile = /usr/local/ispconfig/interface/ssl/rapidssl.chain.server.crt
#Eingetragen für sichere SSL-Methoden
smtpd_tls_exclude_ciphers = RC4, aNULL
smtp_tls_exclude_ciphers = RC4, aNULL
smtpd_tls_ciphers = high
smtp_tls_security_level = may
smtpd_tls_protocols = !SSLv2,!SSLv3
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $sender_bcc_maps $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $smtpd_sender_login_maps
smtpd_sender_restrictions = check_sender_access regexp:/etc/postfix/tag_as_originating.re , permit_mynetworks, permit_sasl_authenticated, check_sender_access mysql:/etc/postfix/mysql-virtual_sender.cf, check_sender_access regexp:/etc/postfix/tag_as_foreign.re
smtpd_client_message_rate_limit = 100
virtual_transport = dovecot
owner_request_special = no
smtpd_sasl_type = dovecot
message_size_limit = 0
smtpd_tls_dh1024_param_file = /etc/postfix/dh_1024.pem
smtpd_tls_dh512_param_file = /etc/postfix/dh_512.pem
smtpd_tls_eecdh_grade = strong
tls_preempt_cipherlist = yes
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3
smtp_tls_protocols = !SSLv2,!SSLv3
smtpd_relay_restrictions = permit_mynetworks, permit_sasl_authenticated, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, reject_unauth_destination, reject_rbl_client ix.dnsbl.manitu.net, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client dul.dnsbl.sorbs.net, reject_rbl_client bl.spamcop.net, reject_rbl_client psbl.surriel.com, reject_rbl_client noptr.spamrats.com
sender_bcc_maps = proxy:mysql:/etc/postfix/mysql-virtual_outgoing_bcc.cf
smtpd_restriction_classes = greylisting
greylisting = check_policy_service inet:127.0.0.1:10023
smtpd_sender_login_maps = proxy:mysql:/etc/postfix/mysql-virtual_sender_login_maps.cf
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_sasl_authenticated, permit_mynetworks, check_helo_access regexp:/etc/postfix/helo_access, reject_invalid_hostname, reject_non_fqdn_hostname, check_helo_access regexp:/etc/postfix/blacklist_helo
