D
Deleted member 5906
Guest
Hi,
folgende Meldung erscheint alle 5 Minuten in der mail.log:
Als Hostname/Mailname wird server.example.com genutzt.
postconf -nf
server
hostname -f
server.example.com
cat /etc/mailname
server.example.com
Kann mir dabei jemand weiterhelfen?
Kurz zur Anmerkung, es handelt sich um einen kleinen VPS von OVH ohne ISPConfig.Apr 19 17:55:07 server postfix/smtpd[24553]: connect from unknown[unknown]
Apr 19 17:55:07 server postfix/smtpd[24553]: lost connection after CONNECT from unknown[unknown]
Apr 19 17:55:07 server postfix/smtpd[24553]: disconnect from unknown[unknown]
Apr 19 17:58:28 server postfix/anvil[24555]: statistics: max connection rate 1/60s for (smtp:unknown) at Apr 19 17:55:07
Apr 19 17:58:28 server postfix/anvil[24555]: statistics: max connection count 1 for (smtp:unknown) at Apr 19 17:55:07
Apr 19 17:58:28 server postfix/anvil[24555]: statistics: max cache size 1 at Apr 19 17:55:07
postconf -nf
postconf -Mfaccess_map_reject_code = 554
append_at_myorigin = yes
append_dot_mydomain = no
biff = no
bounce_queue_lifetime = 3d
config_directory = /etc/postfix
delay_warning_time = 2d
inet_interfaces = all
invalid_hostname_reject_code = 554
mailbox_size_limit = 0
maps_rbl_reject_code = 554
maximal_queue_lifetime = 3d
message_size_limit = 104857600
multi_recipient_bounce_reject_code = 554
mydestination = $myhostname, localhost.localdomain, localhost
myhostname = server.example.com
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
myorigin = /etc/mailname
non_fqdn_reject_code = 554
plaintext_reject_code = 554
recipient_delimiter = +
reject_code = 554
relay_domains_reject_code = 554
relayhost =
smtp_tls_CAfile = /etc/ssl/private/ca-startssl-class1.pem
smtpd_client_restrictions = permit_mynetworks, reject_unknown_client,
reject_invalid_hostname, reject_rbl_client zen.spamhaus.org, permit
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_sasl_authenticated, permit_mynetworks,
reject_unauth_destination, reject_non_fqdn_sender,
reject_non_fqdn_recipient, reject_unknown_recipient_domain,
reject_non_fqdn_hostname, reject_invalid_hostname, reject_rhsbl_client
rhsbl.sorbs.net, reject_rhsbl_sender rhsbl.sorbs.net, reject_rbl_client
opm.blitzed.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client
relays.ordb.org, reject_rbl_client list.dsbl.org, reject_rbl_client
sbl.spamhaus.org, reject_rbl_client unconfirmed.dsbl.org, reject_rbl_client
list.dsbl.org, reject_rbl_client dynablock.njabl.org, reject_rbl_client
dialup.blacklist.jippg.org, reject_rbl_client opm.blitzed.org,
reject_rbl_client cbl.abuseat.org, reject_rbl_client multihop.dsbl.org,
reject_rbl_client dialup.rbl.kropka.net, reject_unauth_pipelining
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks,
reject_invalid_hostname, reject_non_fqdn_hostname, reject_non_fqdn_sender,
reject_non_fqdn_recipient, reject_unknown_sender_domain,
reject_unknown_recipient_domain, reject_unauth_pipelining,
reject_unauth_destination, reject_rbl_client zombie.dnsbl.sorbs.net,
reject_rbl_client relays.ordb.org, reject_rbl_client opm.blitzed.org,
reject_rbl_client list.dsbl.org, reject_rbl_client sbl.spamhaus.org,
reject_rbl_client blackholes.easynet.nl, reject_rbl_client
unconfirmed.dsbl.org, reject_rbl_client dynablock.njabl.org,
reject_rbl_client dialup.blacklist.jippg.org, reject_rbl_client
cbl.abuseat.org, permit
smtpd_sasl_auth_enable = yes
smtpd_sender_restrictions = permit_sasl_authenticated, permit_mynetworks,
reject_unauth_destination, reject_rhsbl_client rhsbl.sorbs.net,
reject_rhsbl_sender rhsbl.sorbs.net, reject_rbl_client relays.ordb.org,
reject_rbl_client unconfirmed.dsbl.org, reject_rbl_client list.dsbl.org,
dialup.blacklist.jippg.org, reject_rbl_client multihop.dsbl.org,
reject_rbl_client dialup.rbl.kropka.net, reject_rbl_client opm.blitzed.org,
reject_rbl_client cbl.abuseat.org, reject_non_fqdn_sender,
smtpd_tls_loglevel = 1
smtpd_use_tls = yes
unknown_address_reject_code = 554
unknown_client_reject_code = 450
unknown_hostname_reject_code = 450
unknown_local_recipient_reject_code = 554
unknown_relay_recipient_reject_code = 554
unknown_virtual_alias_reject_code = 554
unknown_virtual_mailbox_reject_code = 554
unverified_recipient_reject_code = 554
unverified_sender_reject_code = 554
hostnamesmtp inet n - - - - smtpd
submission inet n - - - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
smtps inet n - - - - smtpd
-o syslog_name=postfix/smtps
-o smtpd_tls_wrappermode=yes
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail
($recipient)
server
hostname -f
server.example.com
cat /etc/mailname
server.example.com
