planet_fox
Super-Moderator
Habe hier folgende Info nach Backup versuch, könnte das auf Speicherprobleme hin deuten auf der Hauptmaschine
Nov 24 20:22:55 INFO: sent 38382057695 bytes received 4236511 bytes 7102654.12 bytes/sec
Nov 24 20:22:55 INFO: total size is 38368847046 speedup is 1.00
Nov 24 20:22:55 INFO: rsync warning: some files vanished before they could be transferred (code 24) at main.c(1060) [sender=3.0.7]
Nov 24 20:22:55 INFO: first sync finished (5405 seconds)
Nov 24 20:22:55 INFO: suspend vm
Nov 24 20:22:55 INFO: Setting up checkpoint...
Nov 24 20:22:55 INFO: suspend...
Nov 24 20:22:55 INFO: Can not suspend container: Device or resource busy
Nov 24 20:22:55 INFO: Error: task 16646/1003(ntpd) uses posix timers
Nov 24 20:22:55 INFO: Checkpointing failed
Nov 24 20:23:05 ERROR: Backup of VM 101 failed - command 'vzctl --skiplock chkpnt 101 --suspend' failed with exit code 16
