Seit 3.1.1 kein Zugriff mehr auf ISPConfig Webinterface
fw114
Update gefahren, Dienste neu konfigurieren lassen und seit dem Update kein Zugriff mehr auf das Webinterface
Ich muss dazu sagen, das bei mir das Interface auf 8181 liegt.
Soweit so gut. Alle Webseiten laufen bis auf das Ispconfig Webinterface
netstat -taupen |grep 8181
tcp 0 0 0.0.0.0:8181 0.0.0.0:* LISTEN 0 87244 12794/apache2
netstat -taupen |grep 80
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 87242 12794/apache2
lupo3:/etc/apache2/sites-available# journalctl -xe
Nov 01 12:10:53 lupo3 apache2[12758]: Starting web server: apache2AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/000-ispconfig.conf:69
Nov 01 12:10:53 lupo3 apache2[12758]: [Tue Nov 01 12:10:53.096237 2016] [alias:warn] [pid 12771] AH00671: The Alias directive in /etc/apache2/sites-enabled/000-ispconfig.conf at line 64 will probably never match because it overlaps an ea
Nov 01 12:10:53 lupo3 apache2[12758]: [Tue Nov 01 12:10:53.097391 2016] [alias:warn] [pid 12771] AH00671: The ScriptAlias directive in /etc/apache2/conf.d/mailman.conf at line 4 will probably never match because it overlaps an earlier Sc
Nov 01 12:10:53 lupo3 apache2[12758]: [Tue Nov 01 12:10:53.097430 2016] [alias:warn] [pid 12771] AH00671: The Alias directive in /etc/apache2/conf.d/phpmyadmin.conf at line 3 will probably never match because it overlaps an earlier Alias
Nov 01 12:10:53 lupo3 apache2[12758]: [Tue Nov 01 12:10:53.097512 2016] [alias:warn] [pid 12771] AH00671: The ScriptAlias directive in /etc/mailman/apache.conf at line 4 will probably never match because it overlaps an earlier ScriptAlia
Nov 01 12:10:53 lupo3 apache2[12758]: [Tue Nov 01 12:10:53.097516 2016] [alias:warn] [pid 12771] AH00671: The Alias directive in /etc/mailman/apache.conf at line 8 will probably never match because it overlaps an earlier Alias.
Nov 01 12:10:54 lupo3 apache2[12758]: .
Nov 01 12:10:54 lupo3 systemd[1]: Started LSB: Apache2 web server.
-- Subject: Unit apache2.service has finished start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit apache2.service has finished starting up.
-- The start-up result is done.
florian030
Hast Du ein self-signed ssl-cert dafür? Das mögen manche Browser nicht immer. Firefox ist da ab und an etwas eigen. Sonst schau mal nach der Firewall
