Folgendes Problem tritt nach dem Update auf:
apachectl restart
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/000-ispconfig.conf:62
[Mon Apr 11 20:12:16.495891 2016] [alias:warn] [pid 25319] AH00671: The ScriptAlias directive in /etc/apache2/conf.d/mailman.conf at line 4 will probably never match because it overlaps an earlier ScriptAlias.
[Mon Apr 11 20:12:16.495969 2016] [alias:warn] [pid 25319] AH00671: The Alias directive in /etc/apache2/conf.d/phpmyadmin.conf at line 3 will probably never match because it overlaps an earlier Alias.
[Mon Apr 11 20:12:16.496065 2016] [alias:warn] [pid 25319] AH00671: The ScriptAlias directive in /etc/mailman/apache.conf at line 4 will probably never match because it overlaps an earlier ScriptAlias.
[Mon Apr 11 20:12:16.496083 2016] [alias:warn] [pid 25319] AH00671: The Alias directive in /etc/mailman/apache.conf at line 8 will probably never match because it overlaps an earlier Alias.
httpd not running, trying to start
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:8080
no listening sockets available, shutting down
AH00015: Unable to open logs
Action 'restart' failed.
The Apache error log may have more information.
Sprich: Irgendwo ist ein Listen xxx doppelt drin.
Aber wieso nach dem Update ?
OK, in der
000-apps.vhost steht:
Listen 8080
# NameVirtualHost *:8080
und in der 000-ispconfig.vhost
Listen 8080
Nehme ich die raus, komme ich natürlich nicht mehr auf die ispconfig seite. aber wie stimmt es denn jetzt. bzw wie muss die config sein ?
apachectl restart
OK, in der
Listen 8080
Listen 8080
