Oct 8 18:10:02 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:10:02 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:10:02 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:10:02 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:10:02 crazyhome postfix/smtpd[24407]: connect from localhost[127.0.0.1]
Oct 8 18:10:02 crazyhome postfix/smtpd[24407]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:10:02 crazyhome postfix/smtpd[24407]: disconnect from localhost[127.0.0.1]
Oct 8 18:15:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:15:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:15:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:15:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:15:01 crazyhome postfix/smtpd[24471]: connect from localhost[127.0.0.1]
Oct 8 18:15:01 crazyhome postfix/smtpd[24471]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:15:01 crazyhome postfix/smtpd[24471]: disconnect from localhost[127.0.0.1]
Oct 8 18:20:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:20:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:20:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:20:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:20:01 crazyhome postfix/smtpd[24543]: connect from localhost[127.0.0.1]
Oct 8 18:20:01 crazyhome postfix/smtpd[24543]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:20:01 crazyhome postfix/smtpd[24543]: disconnect from localhost[127.0.0.1]
Oct 8 18:25:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:25:02 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:25:02 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:25:02 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:25:02 crazyhome postfix/smtpd[24610]: connect from localhost[127.0.0.1]
Oct 8 18:25:02 crazyhome postfix/smtpd[24610]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:25:02 crazyhome postfix/smtpd[24610]: disconnect from localhost[127.0.0.1]
Oct 8 18:25:58 crazyhome postfix/qmgr[27132]: CACCC3F42D0: from=, size=1125, nrcpt=1 (queue active)
Oct 8 18:26:28 crazyhome postfix/smtp[24629]: connect to mx0.gmx.net[213.165.64.100]:25: Connection timed out
Oct 8 18:26:58 crazyhome postfix/smtp[24629]: connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out
Oct 8 18:26:58 crazyhome postfix/smtp[24629]: CACCC3F42D0: to=, relay=none, delay=61515, delays=61455/0.1/60/0, dsn=4.4.1, status=deferred (connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out)
Oct 8 18:30:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:30:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:30:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:30:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:30:01 crazyhome postfix/smtpd[24679]: connect from localhost[127.0.0.1]
Oct 8 18:30:01 crazyhome postfix/smtpd[24679]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:30:01 crazyhome postfix/smtpd[24679]: disconnect from localhost[127.0.0.1]
Oct 8 18:30:58 crazyhome postfix/qmgr[27132]: 98A143F42CC: from=, size=1249, nrcpt=1 (queue active)
Oct 8 18:31:28 crazyhome postfix/smtp[24698]: connect to mx0.gmx.net[213.165.64.100]:25: Connection timed out
Oct 8 18:31:58 crazyhome postfix/smtp[24698]: connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out
Oct 8 18:31:58 crazyhome postfix/smtp[24698]: 98A143F42CC: to=, relay=none, delay=65695, delays=65635/0.1/60/0, dsn=4.4.1, status=deferred (connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out)
Oct 8 18:35:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:35:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:35:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:35:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:35:01 crazyhome postfix/smtpd[24749]: connect from localhost[127.0.0.1]
Oct 8 18:35:01 crazyhome postfix/smtpd[24749]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:35:01 crazyhome postfix/smtpd[24749]: disconnect from localhost[127.0.0.1]
Oct 8 18:35:58 crazyhome postfix/qmgr[27132]: ED2893F42D1: from=, size=1148, nrcpt=1 (queue active)
Oct 8 18:36:28 crazyhome postfix/smtp[24768]: connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out
Oct 8 18:36:58 crazyhome postfix/smtp[24768]: connect to mx0.gmx.net[213.165.64.100]:25: Connection timed out
Oct 8 18:36:58 crazyhome postfix/smtp[24768]: ED2893F42D1: to=, relay=none, delay=61574, delays=61513/0.1/60/0, dsn=4.4.1, status=deferred (connect to mx0.gmx.net[213.165.64.100]:25: Connection timed out)
Oct 8 18:40:02 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:40:02 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:40:02 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:40:02 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:40:02 crazyhome postfix/smtpd[24834]: connect from localhost[127.0.0.1]
Oct 8 18:40:02 crazyhome postfix/smtpd[24834]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:40:02 crazyhome postfix/smtpd[24834]: disconnect from localhost[127.0.0.1]
Oct 8 18:45:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:45:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:45:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:45:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:45:01 crazyhome postfix/smtpd[24898]: connect from localhost[127.0.0.1]
Oct 8 18:45:01 crazyhome postfix/smtpd[24898]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:45:01 crazyhome postfix/smtpd[24898]: disconnect from localhost[127.0.0.1]
Oct 8 18:50:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:50:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:50:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:50:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:50:01 crazyhome postfix/smtpd[24964]: connect from localhost[127.0.0.1]
Oct 8 18:50:01 crazyhome postfix/smtpd[24964]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:50:01 crazyhome postfix/smtpd[24964]: disconnect from localhost[127.0.0.1]
Oct 8 18:55:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:55:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 18:55:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 18:55:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 18:55:02 crazyhome postfix/smtpd[25031]: connect from localhost[127.0.0.1]
Oct 8 18:55:02 crazyhome postfix/smtpd[25031]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 18:55:02 crazyhome postfix/smtpd[25031]: disconnect from localhost[127.0.0.1]
Oct 8 19:00:02 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:00:02 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 19:00:02 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:00:02 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 19:00:02 crazyhome postfix/smtpd[25096]: connect from localhost[127.0.0.1]
Oct 8 19:00:02 crazyhome postfix/smtpd[25096]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 19:00:02 crazyhome postfix/smtpd[25096]: disconnect from localhost[127.0.0.1]
Oct 8 19:05:01 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:05:01 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 19:05:01 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:05:01 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 8 19:05:02 crazyhome postfix/smtpd[25174]: connect from localhost[127.0.0.1]
Oct 8 19:05:02 crazyhome postfix/smtpd[25174]: lost connection after CONNECT from localhost[127.0.0.1]
Oct 8 19:05:02 crazyhome postfix/smtpd[25174]: disconnect from localhost[127.0.0.1]
Oct 8 19:10:02 crazyhome pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:10:02 crazyhome pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 8 19:10:02 crazyhome imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 8 19:10:02 crazyhome imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
