NeoFireStorm
Hallo ich habe das Klasse ISPConfig3 HowTo gemacht wo auch Squirrelmail mit installiert wird. Nun habe ich ein Testmail account angelegt und wollte einloggen und habe dann die Fehlermeldung:
ERROR: Connection dropped by IMAP server.
bekommen. Ich finde den Fehler nicht wirklich. Vielleicht habt ihr ne Idee was der Log mir von mail.log sagen möchte ?
Dec 31 11:30:21 Debian-70-wheezy-64-minimal dovecot: master: Dovecot v2.1.7 starting up (core dumps disabled)
Dec 31 11:30:22 Debian-70-wheezy-64-minimal dovecot: ssl-params: Generating SSL parameters
Dec 31 11:30:22 Debian-70-wheezy-64-minimal dovecot: master: Warning: Killed with signal 15 (by pid=16448 uid=0 code=kill)
Dec 31 11:30:22 Debian-70-wheezy-64-minimal dovecot: master: Dovecot v2.1.7 starting up (core dumps disabled)
Dec 31 11:30:23 Debian-70-wheezy-64-minimal dovecot: master: Warning: Killed with signal 15 (by pid=16608 uid=0 code=kill)
Dec 31 11:30:23 Debian-70-wheezy-64-minimal dovecot: master: Dovecot v2.1.7 starting up (core dumps disabled)
Dec 31 11:30:24 Debian-70-wheezy-64-minimal dovecot: master: Warning: Killed with signal 15 (by pid=16769 uid=0 code=kill)
Dec 31 11:30:24 Debian-70-wheezy-64-minimal dovecot: master: Dovecot v2.1.7 starting up (core dumps disabled)
Dec 31 11:30:25 Debian-70-wheezy-64-minimal dovecot: ssl-params: SSL parameters regeneration completed
Dec 31 11:30:39 Debian-70-wheezy-64-minimal postfix/master[17148]: daemon started -- version 2.9.6, configuration /etc/postfix
Dec 31 11:33:25 Debian-70-wheezy-64-minimal postfix/master[17148]: terminating on signal 15
Dec 31 11:33:25 Debian-70-wheezy-64-minimal postfix/master[24105]: daemon started -- version 2.9.6, configuration /etc/postfix
Dec 31 12:05:43 Debian-70-wheezy-64-minimal postfix/master[24105]: terminating on signal 15
Dec 31 12:05:43 Debian-70-wheezy-64-minimal postfix/master[11831]: daemon started -- version 2.9.6, configuration /etc/postfix
Dec 31 12:06:37 Debian-70-wheezy-64-minimal postfix/smtpd[11947]: connect from localhost[127.0.0.1]
Dec 31 12:06:37 Debian-70-wheezy-64-minimal postfix/smtpd[11947]: 04BF02740F8E: client=localhost[127.0.0.1]
Dec 31 12:06:37 Debian-70-wheezy-64-minimal postfix/cleanup[11951]: 04BF02740F8E: message-id=<mailman.0.1388487846.11686.mailman@static.17.96.46.78.your-server.de>
Dec 31 12:06:37 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: 04BF02740F8E: from=<mailman-bounces@static.17.96.46.78.your-server.de>, size=2318, nrcpt=1 (queue active)
Dec 31 12:06:37 Debian-70-wheezy-64-minimal postfix/smtpd[11947]: disconnect from localhost[127.0.0.1]
Dec 31 12:06:38 Debian-70-wheezy-64-minimal postfix/smtp[11952]: 04BF02740F8E: to=<theweedbrothershb@gmail.com>, relay=gmail-smtp-in.l.google.com[173.194.70.26]:25, delay=1.2, delays=0.19/0.01/0.12/0.84, dsn=2.0.0, status=sent (250 2.0.0 OK 1388487998 l2si56856342een.125 - gsmtp)
Dec 31 12:06:38 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: 04BF02740F8E: removed
Dec 31 12:09:01 Debian-70-wheezy-64-minimal postfix/pickup[11841]: EF8052740B21: uid=0 from=<root>
Dec 31 12:09:01 Debian-70-wheezy-64-minimal postfix/cleanup[13821]: EF8052740B21: message-id=<20131231110901.EF8052740B21@Debian-70-wheezy-64-minimal>
Dec 31 12:09:02 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: EF8052740B21: from=<root@static.17.96.46.78.your-server.de>, size=1151, nrcpt=1 (queue active)
Dec 31 12:09:02 Debian-70-wheezy-64-minimal postfix/local[13823]: EF8052740B21: to=<root@static.17.96.46.78.your-server.de>, orig_to=<root>, relay=local, delay=0.44, delays=0.24/0.01/0/0.19, dsn=2.0.0, status=sent (delivered to mailbox)
Dec 31 12:09:02 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: EF8052740B21: removed
Dec 31 12:18:04 Debian-70-wheezy-64-minimal postfix/pickup[11841]: 52EB5274100C: uid=110 from=<amavis>
Dec 31 12:18:04 Debian-70-wheezy-64-minimal postfix/cleanup[16647]: 52EB5274100C: message-id=<20131231111804.52EB5274100C@Debian-70-wheezy-64-minimal>
Dec 31 12:18:04 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: 52EB5274100C: from=<amavis@static.17.96.46.78.your-server.de>, size=733, nrcpt=1 (queue active)
Dec 31 12:18:04 Debian-70-wheezy-64-minimal postfix/local[16649]: 52EB5274100C: to=<amavis@static.17.96.46.78.your-server.de>, orig_to=<amavis>, relay=local, delay=0.28, delays=0.15/0.01/0/0.13, dsn=2.0.0, status=sent (delivered to mailbox)
Dec 31 12:18:04 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: 52EB5274100C: removed
Dec 31 12:39:01 Debian-70-wheezy-64-minimal postfix/pickup[11841]: AAB9D274101D: uid=0 from=<root>
Dec 31 12:39:01 Debian-70-wheezy-64-minimal postfix/cleanup[17442]: AAB9D274101D: message-id=<20131231113901.AAB9D274101D@Debian-70-wheezy-64-minimal>
Dec 31 12:39:01 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: AAB9D274101D: from=<root@static.17.96.46.78.your-server.de>, size=1151, nrcpt=1 (queue active)
Dec 31 12:39:01 Debian-70-wheezy-64-minimal postfix/local[17444]: AAB9D274101D: to=<root@static.17.96.46.78.your-server.de>, orig_to=<root>, relay=local, delay=0.45, delays=0.34/0.01/0/0.11, dsn=2.0.0, status=sent (delivered to mailbox)
Dec 31 12:39:01 Debian-70-wheezy-64-minimal postfix/qmgr[11842]: AAB9D274101D: removed
Dec 31 12:45:28 Debian-70-wheezy-64-minimal postfix/master[11831]: terminating on signal 15
Dec 31 12:45:28 Debian-70-wheezy-64-minimal postfix/master[18531]: daemon started -- version 2.9.6, configuration /etc/postfix
Dec 31 12:45:35 Debian-70-wheezy-64-minimal dovecot: master: Warning: Killed with signal 15 (by pid=19495 uid=0 code=kill)
Dec 31 12:45:35 Debian-70-wheezy-64-minimal dovecot: master: Dovecot v2.1.7 starting up (core dumps disabled)
Dec 31 12:50:01 Debian-70-wheezy-64-minimal dovecot: imap-login: Disconnected (disconnected before greeting, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<q6IQKdPugwB/AAAB>
Dec 31 12:50:01 Debian-70-wheezy-64-minimal dovecot: auth: Fatal: Unknown database driver 'mysql'
Dec 31 12:50:01 Debian-70-wheezy-64-minimal dovecot: master: Error: service(auth): command startup failed, throttling for 2 secs
Dec 31 12:50:01 Debian-70-wheezy-64-minimal dovecot: pop3-login: Disconnected: Auth process broken (disconnected before greeting, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<H78QKdPuYwB/AAAB>
Dec 31 12:50:01 Debian-70-wheezy-64-minimal postfix/smtpd[19712]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Dec 31 12:50:01 Debian-70-wheezy-64-minimal postfix/smtpd[19712]: connect from localhost[127.0.0.1]
Dec 31 12:50:03 Debian-70-wheezy-64-minimal dovecot: auth: Fatal: Unknown database driver 'mysql'
Dec 31 12:50:03 Debian-70-wheezy-64-minimal dovecot: master: Error: service(auth): command startup failed, throttling for 4 secs
Dec 31 12:50:03 Debian-70-wheezy-64-minimal postfix/smtpd[19712]: fatal: no SASL authentication mechanisms
Dec 31 12:50:04 Debian-70-wheezy-64-minimal postfix/master[18531]: warning: process /usr/lib/postfix/smtpd pid 19712 exit status 1
Dec 31 12:50:04 Debian-70-wheezy-64-minimal postfix/master[18531]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Dec 31 12:52:14 Debian-70-wheezy-64-minimal dovecot: auth: Fatal: Unknown database driver 'mysql'
Dec 31 12:52:14 Debian-70-wheezy-64-minimal dovecot: master: Error: service(auth): command startup failed, throttling for 8 secs
Dec 31 12:52:14 Debian-70-wheezy-64-minimal dovecot: imap-login: Disconnected: Auth process broken (disconnected before greeting, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<bEr8MNPuhQB/AAAB>
