Problem bei ISPConfig-Installation auf Debian Etch
daff
ich hab ein Problem bei der Installation von ISPConfig auf einem Debian Etch System, dass ich nach dem Tutorial "Perfect Setup - Debian Etch" installiert habe. Ich bekomme folgende Meldung:
Configuring extensions
checking whether to enable LIBXML support... no
checking libxml2 install dir... no
checking for OpenSSL support... yes
checking for Kerberos support... no
checking for DSA_get_default_method in -lssl... yes
checking for pkg-config... no
configure: error: Cannot find OpenSSL's <evp.h>
ERROR: Could not configure PHP
cd: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
mv: cannot stat `binaries/aps.tar.gz': No such file or directory
mv: cannot stat `binaries/spamassassin.tar.gz': No such file or directory
mv: cannot stat `binaries/uudeview.tar.gz': No such file or directory
mv: cannot stat `binaries/clamav.tar.gz': No such file or directory
mv: cannot stat `binaries/cronolog': No such file or directory
mv: cannot stat `binaries/cronosplit': No such file or directory
mv: cannot stat `binaries/ispconfig_tcpserver': No such file or directory
mv: cannot stat `binaries/zip': No such file or directory
mv: cannot stat `binaries/unzip': No such file or directory
tar: spamassassin.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
mv: cannot stat `spamassassin': No such file or directory
tar: uudeview.tar.gz: Cannot open: No such file or directory
mv: cannot stat `uudeview': No such file or directory
tar: clamav.tar.gz: Cannot open: No such file or directory
mv: cannot stat `clamav': No such file or directory
tar: aps.tar.gz: Cannot open: No such file or directory
./setup2: line 873: ispconfig_tmp/php/bin/php: No such file or directory
ERROR: Das mitgelieferte PHP-Binary funktioniert auf Ihrem System nicht! Die Installation bricht hier ab!
Woran liegt das?
EDIT: ich nutze folgenden Kernel:
2.6.18-5-xen-amd64
Ich hab auch nochma gegoogelt und folgenden Beitrag gefunden:
http://www.howtoforge.com/forums/showthread.php?p=93850
Der letzte Beitrag sagt, dass man das compilescript ändern soll:
Please try to set the openssl path in the compile script to:
/usr/include/openssl
Wo muss ich das eintragen ?
EDIT2: Ich hab den Eintrag nach der Anleitung geändert aber der Fehler kommt immer noch.
MfG
Daff
Stell bitte sicher, dass Du auch eine 64bit debian install cd zum installieren genommen hast und nicht nur einen 64bit kernel installiert hat.
daff
Wie kann ich das raus finden ? Ich habe einen VServer der von meinem Provider automatisch installiert wurde.
daff
Ich hab jetzt mal libcurl3-openssl-dev installiert und jetzt kommt folgendes:
make: *** [ext/openssl/openssl.lo] Error 1
ERROR: Could not make PHP
daff
Gibt es irgendwelche Fehler vor der Error Zeile?
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2503: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2530: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2586: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2644: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2663: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2678: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2700: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2761: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:2870: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3031: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3142: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3211: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3269: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3335: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3393: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3461: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3481: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3531: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3572: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3685: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3736: error:                                 expected declaration specifiers or '...' before 'X509_STORE_CTX'
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3737: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3775: error:                                 expected ')' before '*' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3846: error:                                 expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3864: error:                                 expected declaration specifiers before 'SSL'
/tmp/install_ispconfig/compile_aps/php-5.2.4/ext/openssl/openssl.c:3953: error:                                 expected '{' at end of input
EDIT: ich hab jetzt nochmal alle Pakete, die bei dem Tutorial installiert werden gelöscht und neu installiert und jetzt kommt folgende Meldung:
configure: creating ./config.status
config.status: creating Makefile
config.status: creating spamc.h
config.status: creating config.h
make -f spamc/Makefile spamc/spamc
make[1]: Entering directory `/tmp/install_ispconfig/compile_aps/Mail-SpamAssassin-3.2.3'
gcc  -g -O2 spamc/spamc.c spamc/getopt.c spamc/libspamc.c spamc/utils.c \
                -o spamc/spamc   -ldl -lz
spamc/getopt.c: In function 'spamc_getopt_long':
spamc/getopt.c:254: error: stray '\240' in program
spamc/getopt.c:254: error: stray '`' in program
make[1]: *** [spamc/spamc] Error 1
make[1]: Leaving directory `/tmp/install_ispconfig/compile_aps/Mail-SpamAssassin-3.2.3'
make: *** [spamc/spamc] Error 2
ERROR: Could not make SpamAssassin
rm: cannot remove `apache_1.3.39/src/support/dbmmanage.1': Operation not permitted
rm: cannot remove `install_ispconfig/compile_aps/apache_1.3.39/src/support/dbmmanage.1': Operation not permitted
daff
So es hat sich geklärt... nachdem ich nochmal alle pakete runtergehaun habe geht jetzt der server endlich
