Also habe in Forum schon gesucht aber nichts gefunden was mir weiter geholfen hat.
Beim senden von mails kommt im mailclient ->
Konto "blah.blub@blahblub.de" sendet einen Fehler, Fehlercode: 554; Fehlerinformation: 554 5.7.1 <blah@gmx.de>: Relay access denied
Beim empfangen passiert garnix :/
auszug ausser var/log/mail
habt bitte nachsicht -> ist mein erster server mit ispconfig/postfix/etc
Aug 14 16:28:54 kkh1 postfix/master[4860]: reload configuration /etc/postfix
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: 986A12E1B4: from=<beetlestn@tampabay.rr.com>, size=48272, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: E56F22E1C0: from=<>, size=4203, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: CAD5B2E1B8: from=<blah@gmx.de>, size=1551, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: A21EA2E1B6: from=<>, size=3614, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: 2AE6C2E1B7: from=<blah@gmx.de>, size=1706, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: 590D62E1BC: from=<>, size=3628, nrcpt=1 (queue active)
Aug 14 16:28:54 kkh1 postfix/qmgr[7874]: 95C342E1B9: from=<>, size=3546, nrcpt=1 (queue active)
Aug 14 16:29:00 kkh1 pop3d: Connection, ip=[::ffff:77.179.87.111]
Aug 14 16:29:00 kkh1 postfix/smtpd[7887]: connect from drsd-4db3576f.pool.einsundeins.de[77.179.87.111]
Aug 14 16:29:01 kkh1 pop3d: LOGIN, user=web6_mirko, ip=[::ffff:77.179.87.111], port=[64922]
Aug 14 16:29:01 kkh1 pop3d: LOGOUT, user=web6_mirko, ip=[::ffff:77.179.87.111], port=[64922], top=0, retr=0, rcvd=12, sent=39, time=0
Aug 14 16:29:01 kkh1 postfix/smtpd[7887]: NOQUEUE: reject: RCPT from drsd-4db3576f.pool.einsundeins.de[77.179.87.111]: 554 5.7.1 <blah@gmx.de>: Relay access denied; from=<blah.blub@blahblub.de> to=<blah@gmx.de> proto=ESMTP helo=<PC_OBEN_M>
Aug 14 16:29:01 kkh1 postfix/smtpd[7887]: disconnect from drsd-4db3576f.pool.einsundeins.de[77.179.87.111]
Aug 14 16:30:05 kkh1 amavis[2028]: (02028-04) Blocked SPAM, [212.163.164.16] <bconde@tea-cegos.es> -> <webmaster@blahblub.de>, quarantine: spam-zQ7FG-kEG1oC.gz, Message-ID: <201d01c8fe23$5be7d690$c0a85661@Jean>, mail_id: zQ7FG-kEG1oC, Hits: 24.618, size: 2220, 13764 ms
Aug 14 16:30:05 kkh1 postfix/smtp[7954]: 875082E1BE: to=<webmaster@blahblub.de>, relay=127.0.0.1[127.0.0.1]:10024, delay=21, delays=7.4/0.01/0/14, dsn=2.5.0, status=sent (250 2.5.0 Ok, id=02028-04, DISCARD(bounce.suppressed))
Aug 14 16:30:05 kkh1 postfix/qmgr[7874]: 875082E1BE: removed
Aug 14 16:30:22 kkh1 postfix/virtual[8012]: fatal: bad string length 0 < 1: virtual_mailbox_base =
Aug 14 16:30:23 kkh1 postfix/master[4860]: warning: process /usr/lib/postfix/virtual pid 8012 exit status 1
Aug 14 16:30:23 kkh1 postfix/master[4860]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Aug 14 16:30:24 kkh1 postfix/smtp[7877]: connect to trebuchet.netdoor.com[208.148.192.206]:25: Connection timed out
Aug 14 16:30:24 kkh1 postfix/smtp[7877]: E56F22E1C0: to=<shaunna_sybilkk@netdoor.com>, relay=none, delay=9628, delays=9538/0.01/90/0, dsn=4.4.1, status=deferred (connect to trebuchet.netdoor.com[208.148.192.206]:25: Connection timed out)
