PHP5 mit Zend OPcache And APCu
Da muss irgend ein Fehler im make output vermerkt sein, habe das Tutorial auch schon verwendet, es sollte generell so funktionieren.
make test sagt mir folgendes:
FAILED TEST SUMMARY
file_get_contents() test using offset parameter out of range [ext/standard/tests/file/file_get_contents_error001.phpt]
Test setlocale() function : usage variations - Setting all available locales in the platform [ext/standard/tests/strings/setlocale_variation2.phpt]
Habe es jetzt mehrmals versuch, allerdings immer das gleiche.
Hier habe ich einmal einen etwas längeren Output, sagt der dir was ?
Build complete.
Don't forget to run 'make test'.
root@h01 /usr/local/src/php5-build/php-5.5.7 # make install
Installing shared extensions:     /usr/local/lib/php/extensions/no-debug-non-zts-20121212/
Installing PHP CLI binary:        /usr/local/bin/
Installing PHP CLI man page:      /usr/local/php/man/man1/
Installing PHP CGI binary:        /usr/local/bin/
Installing PHP CGI man page:      /usr/local/php/man/man1/
Installing build environment:     /usr/local/lib/php/build/
Installing header files:          /usr/local/include/php/
Installing helper programs:       /usr/local/bin/
  program: phpize
  program: php-config
Installing man pages:             /usr/local/php/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /usr/local/lib/php/
[PEAR] Archive_Tar    - already installed: 1.3.11
[PEAR] Console_Getopt - already installed: 1.3.1
[PEAR] PEAR           - already installed: 1.9.4
Wrote PEAR system config file at: /usr/local/etc/pear.conf
You may want to add: /usr/local/lib/php to your php.ini include_path
[PEAR] Structures_Graph- already installed: 1.0.4
[PEAR] XML_Util       - already installed: 1.2.1
/usr/local/src/php5-build/php-5.5.7/build/shtool install -c ext/phar/phar.phar /usr/local/bin
ln -s -f /usr/local/bin/phar.phar /usr/local/bin/phar
Installing PDO headers:          /usr/local/include/php/ext/pdo/
root@h01 /usr/local/src/php5-build/php-5.5.7 # cp /usr/local/src/php5-build/php-5.5.7/php.ini-production /opt/php-5.5.7/lib/php.ini
cp: cannot create regular file `/opt/php-5.5.7/lib/php.ini': No such file or directory
Ich denke da stimmt schon was beim configure nicht. Make install kopiert nach /usr/local bei dir, er sollte aber nach /opt/.... Kopieren. Als ob der prefix nicht gesetzt ist.
Le-Seaw
wenn ich es für php 5.5.10 machen will ersetze ich ja eigentlich nur die 7 oder?
weil er sucht dann trotzdem den ordner 5.5.7 um logs zu schreiben??
oder habe ich da einen denkfehler?
Wenn Du in allen Befehlen 5.5.7 durch 5.5.10 ersetzt, dann muss er auch einen Ordner 5.5.10 für die Logs verwenden.
