-rwxr-xr-x 1 root root 5583568 2007-11-12 19:01 /usr/bin/php5-cgi
Das sieht soweit ok aus. Dann poste mal:
ls -la /var/www/web10/web/index.php
-rwxrwxr-x 1 web10_1 web10 8491 2007-03-30 16:05 /var/www/web10/web/index.php
x und schau bitte in das error.log der Webseite, welcher Fehler dort geloggt wird. Stelle bitte auch sicher, dass das Wrapperscript ausführbar ist.
[Wed Dec 12 10:36:24 2007] [info] removed PID file /var/run/apache2.pid (pid=23532)
[Wed Dec 12 10:36:24 2007] [notice] caught SIGTERM, shutting down
[Wed Dec 12 10:36:26 2007] [info] Init: Seeding PRNG with 136 bytes of entropy
[Wed Dec 12 10:36:26 2007] [info] Init: Generating temporary RSA private keys (512/1024 bits)
[Wed Dec 12 10:36:26 2007] [info] Init: Generating temporary DH parameters (512/1024 bits)
[Wed Dec 12 10:36:26 2007] [info] Init: Initializing (virtual) servers for SSL
[Wed Dec 12 10:36:26 2007] [info] Server: Apache/2.2.3, Interface: mod_ssl/2.2.3, Library: OpenSSL/0.9.8c
[Wed Dec 12 10:36:26 2007] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Wed Dec 12 10:36:26 2007] [info] mod_unique_id: using ip addr 81.95.0.138
[Wed Dec 12 10:36:27 2007] [notice] ModSecurity for Apache 2.1.1 configured
[Wed Dec 12 10:36:27 2007] [info] Init: Seeding PRNG with 136 bytes of entropy
[Wed Dec 12 10:36:27 2007] [info] Init: Generating temporary RSA private keys (512/1024 bits)
[Wed Dec 12 10:36:27 2007] [info] Init: Generating temporary DH parameters (512/1024 bits)
[Wed Dec 12 10:36:27 2007] [info] Init: Initializing (virtual) servers for SSL
[Wed Dec 12 10:36:27 2007] [info] Server: Apache/2.2.3, Interface: mod_ssl/2.2.3, Library: OpenSSL/0.9.8c
[Wed Dec 12 10:36:27 2007] [info] mod_unique_id: using ip addr 81.95.0.138
[Wed Dec 12 10:36:28 2007] [notice] Apache configured -- resuming normal operations
[Wed Dec 12 10:36:28 2007] [info] Server built: Jun 17 2007 20:24:06
[Wed Dec 12 10:36:40 2007] [error] [client 58.65.237.153] File does not exist: /var/www/sharedip/index, referer: XXXXX
[Wed Dec 12 10:37:06 2007] [info] removed PID file /var/run/apache2.pid (pid=16660)
[Wed Dec 12 10:37:06 2007] [notice] caught SIGTERM, shutting down
[Wed Dec 12 10:37:08 2007] [info] Init: Seeding PRNG with 136 bytes of entropy
[Wed Dec 12 10:37:08 2007] [info] Init: Generating temporary RSA private keys (512/1024 bits)
[Wed Dec 12 10:37:09 2007] [info] Init: Generating temporary DH parameters (512/1024 bits)
[Wed Dec 12 10:37:09 2007] [info] Init: Initializing (virtual) servers for SSL
[Wed Dec 12 10:37:09 2007] [info] Server: Apache/2.2.3, Interface: mod_ssl/2.2.3, Library: OpenSSL/0.9.8c
[Wed Dec 12 10:37:09 2007] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Wed Dec 12 10:37:09 2007] [info] mod_unique_id: using ip addr 81.95.0.138
[Wed Dec 12 10:37:10 2007] [notice] ModSecurity for Apache 2.1.1 configured
[Wed Dec 12 10:37:10 2007] [info] Init: Seeding PRNG with 136 bytes of entropy
[Wed Dec 12 10:37:10 2007] [info] Init: Generating temporary RSA private keys (512/1024 bits)
[Wed Dec 12 10:37:10 2007] [info] Init: Generating temporary DH parameters (512/1024 bits)
[Wed Dec 12 10:37:10 2007] [info] Init: Initializing (virtual) servers for SSL
[Wed Dec 12 10:37:10 2007] [info] Server: Apache/2.2.3, Interface: mod_ssl/2.2.3, Library: OpenSSL/0.9.8c
[Wed Dec 12 10:37:10 2007] [info] mod_unique_id: using ip addr 81.95.0.138
[Wed Dec 12 10:37:11 2007] [notice] Apache configured -- resuming normal operations
[Wed Dec 12 10:37:11 2007] [info] Server built: Jun 17 2007 20:24:06
Das Wrapperscript muss ja durch suphp gestartet werden, dazu benötig es ausführungs Berechtigungen.
#!/bin/sh
BASEDIR=`/usr/bin/dirname ${DOCUMENT_ROOT}`
TMPDIR=${BASEDIR}/phptmp
SESSDIR=${TMPDIR}
if [ X"${php_safe_mode}" != X"On" ]; then
SAFE_MODE="Off"
else
SAFE_MODE="On"
fi
exec /usr/bin/php5-cgi -d open_basedir=${BASEDIR} -d upload_tmp_dir=${TMPDIR} -d session.save_path=${SESSDIR} -d safe_mode=${SAFE_MODE}
SetEnv php_safe_mode On
if($go_info["server"]["apache2_php"] == 'suphp'){
$php .= "suPHP_Engine on\n";
$php .= "suPHP_UserGroup ".$webadmin." web".$web["doc_id"]."\n";
$php .= "AddHandler x-httpd-php .php .php3 .php4 .php5\n";
$php .= "suPHP_AddHandler x-httpd-php\n";
if ($web["web_php_safe_mode"]) {
$php .= "SetEnv php_safe_mode On\n";
} else {
$php .= "SetEnv php_safe_mode Off\n";
if [ X"${use_pear}" == X"On" ]; then
BASEDIR=${BASEDIR}:/usr/share/php
fi
#!/bin/sh
PATH="/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/libexec"
BASEDIR=`dirname ${DOCUMENT_ROOT}`
SESSDIR=${TMPDIR}
SAFE_MODE="Off"
else
SAFE_MODE="On"
fi
fi
exec php-cgi -d open_basedir=${BASEDIR} -d upload_tmp_dir=${TMPDIR} -d session.save_path=${SESSDIR} -d safe_mode=${SAFE_MODE}
#!/bin/sh
SESSDIR=${TMPDIR}
SAFE_MODE="Off"
else
SAFE_MODE="On"
fi
BASEDIR=${BASEDIR}":/var/www/typo3"
habt Ihr vielleicht eine Ahnung, wo ich den Fehler habe?
Was mir in diesem Zusammenhang noch aufgefallen ist... php-Skripte aus dem web-root klappen, aber bei php-Skripten aus dem web eines Benutzers (www.domain.tld/~webnutzer) bieten die Browser nur zum Download an![]()
