[Mon Mar 02 22:08:24 2009] [error] access to /var/www/web45/web/test.rhtml failed for (null), reason: file permissions deny server execution
[Mon Mar 02 22:08:25 2009] [error] access to /var/www/web45/web/test.rhtml failed for (null), reason: file permissions deny server execution
[Mon Mar 02 22:08:25 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/test.rhtml
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: ^
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:08:34 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:08:34 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/test.rhtml
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: ^
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:08:35 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:08:35 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/test.rhtml
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: ^
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:08:36 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:08:36 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/test.rhtml
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: ^
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:09:18 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:11:14 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: ^
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:11:22 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: ^
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:11:23 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
[Mon Mar 02 22:11:23 2009] [error] [client *] File does not exist: /var/www/web45/web/favicon.ico, referer: http://webby24.de/test.rhtml
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: error in ruby
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `load': /var/www/web45/web/test.rhtml:1: syntax error, unexpected '<' (SyntaxError)
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: <html>
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: ^
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:3: unknown regexp option - p
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: syntax error, unexpected '<'
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: </html>
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: /var/www/web45/web/test.rhtml:4: unterminated string meets end of file
[Mon Mar 02 22:11:24 2009] [error] mod_ruby: from /usr/lib/ruby/1.8/apache/ruby-run.rb:53:in `handler'
