hmmm ... das kommt wenn ich eine testdomain anlege ... sehe darin aber nicht wirklich einen Fehler ... Sorry
26.02.2018-15:10 - DEBUG - Calling function 'check_phpini_changes' from plugin 'webserver_plugin' raised by action 'server_plugins_loaded'.
26.02.2018-15:10 - DEBUG - Found 1 changes, starting update process.
26.02.2018-15:10 - DEBUG - Calling function 'ssl' from plugin 'apache2_plugin' raised by event 'web_domain_insert'.
26.02.2018-15:10 - DEBUG - Calling function 'insert' from plugin 'apache2_plugin' raised by event 'web_domain_insert'.
26.02.2018-15:10 - DEBUG - Adding the user: web112
26.02.2018-15:10 - DEBUG - Creating symlink: ln -s /var/www/clients/client1/web112/ /var/www/test88.de
26.02.2018-15:10 - DEBUG - Creating symlink: ln -s /var/www/clients/client1/web112/ /var/www/clients/client1/test88.de
26.02.2018-15:10 - DEBUG - exec: chown -R web112:client1 /var/www/clients/client1/web112/web
26.02.2018-15:10 - DEBUG - exec: chown web112:client1 /var/www/clients/client1/web112/web
26.02.2018-15:10 - DEBUG - exec: usermod --groups sshusers web112 2>/dev/null
26.02.2018-15:10 - DEBUG - Creating fastcgi starter script directory: /var/www/php-fcgi-scripts/web112/
26.02.2018-15:10 - DEBUG - Creating fastcgi starter script: /var/www/php-fcgi-scripts/web112/.php-fcgi-starter
26.02.2018-15:10 - DEBUG - Writing the vhost file: /etc/apache2/sites-available/test88.de.vhost
26.02.2018-15:10 - DEBUG - Creating symlink: /etc/apache2/sites-enabled/100-test88.de.vhost->/etc/apache2/sites-available/test88.de.vhost
26.02.2018-15:10 - DEBUG - Created AWStats config file: /etc/awstats/awstats.test88.de.conf
26.02.2018-15:10 - DEBUG - Apache status is: running
26.02.2018-15:10 - DEBUG - Calling function 'restartHttpd' from module 'web_module'.
26.02.2018-15:11 - DEBUG - Restarting httpd: systemctl restart apache2.service
26.02.2018-15:11 - DEBUG - Apache restart return value is: 0
26.02.2018-15:11 - DEBUG - Apache online status after restart is: running
26.02.2018-15:11 - DEBUG - Processed datalog_id 868
26.02.2018-15:11 - DEBUG - Remove Lock: /usr/local/ispconfig/server/temp/.ispconfig_lock
