Hhallo,
ich habe ispconfig installiert und so auch keine Probleme bisher.
Bia auf das ich nach ca. 24h den mysqld immer neustarten muss weil ich mich nicht am Frontend anmelden kann.
Fehlermeldung s.u.
Ideen?
Grüße IceCast
Warning: mysql_connect() [function.mysql-connect]: Host 'bender' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts' in /home/admispconfig/ispconfig/lib/classes/ispconfig_db_mysql.lib.php on line 77
Warning: mysql_real_escape_string() [function.mysql-real-escape-string]: Access denied for user 'admispconfig'@'localhost' (using password: NO) in /home/admispconfig/ispconfig/web/login/login.php on line 40
Warning: mysql_real_escape_string() [function.mysql-real-escape-string]: A link to the server could not be established in /home/admispconfig/ispconfig/web/login/login.php on line 40
Warning: mysql_real_escape_string() [function.mysql-real-escape-string]: Access denied for user 'admispconfig'@'localhost' (using password: NO) in /home/admispconfig/ispconfig/web/login/login.php on line 41
Warning: mysql_real_escape_string() [function.mysql-real-escape-string]: A link to the server could not be established in /home/admispconfig/ispconfig/web/login/login.php on line 41
Warning: Cannot modify header information - headers already sent by (output started at /home/admispconfig/ispconfig/lib/classes/ispconfig_db_mysql.lib.php:77) in /home/admispconfig/ispconfig/web/login/login.php on line 60
Fehlermeldung s.u.
Ideen?
Grüße IceCast
