# Example configuration file for Munin, generated by 'make build'
# The next three variables specifies where the location of the RRD
# databases, the HTML output, and the logs, severally. They all
# must be writable by the user running munin-cron.
dbdir /var/lib/munin
htmldir /var/www/munin
logdir /var/log/munin
rundir /var/run/munin
# Where to look for the HTML templates
tmpldir /etc/munin/templates
# Make graphs show values per minute instead of per second
#graph_period minute
# Drop somejuser@fnord.comm and anotheruser@blibb.comm an email everytime
# something changes (OK -> WARNING, CRITICAL -> OK, etc)
#contact.someuser.command mail -s "Munin notification" somejuser@fnord.comm
#contact.anotheruser.command mail -s "Munin notification" anotheruser@blibb.comm
# For those with Nagios, the following might come in handy. In addition,
# the services must be defined in the Nagios server as well.
#contact.nagios.command /usr/sbin/send_nsca -H nagios.host.com -c /etc/send_nsca.cfg
# a simple host tree
[server1.european-moto-club.de]
address 127.0.0.1
use_node_name yes
# A more complex example of a host tree
## First our "normal" host.
# [fii.foo.com]
# address foo
## Then our other host...
# [fay.foo.com]
# address fay
## Then we want totals...
# [foo.com;Totals] #Force it into the "foo.com"-domain...
# update no # Turn off data-fetching for this "host".
# # The graph "load1". We want to see the loads of both machines...
# # "fii=fii.foo.com:load.load" means "label=machine:graph.field"
# load1.graph_title Loads side by side
# load1.graph_order fii=fii.foo.com:load.load fay=fay.foo.com:load.load
# # The graph "load2". Now we want them stacked on top of each other.
# load2.graph_title Loads on top of each other
# load2.dummy_field.stack fii=fii.foo.com:load.load fay=fay.foo.com:load.load
# load2.dummy_field.draw AREA # We want area instead the default LINE2.
# load2.dummy_field.label dummy # This is needed. Silly, really.
# # The graph "load3". Now we want them summarised into one field
# load3.graph_title Loads summarised
# load3.combined_loads.sum fii.foo.com:load.load fay.foo.com:load.load
# load3.combined_loads.label Combined loads # Must be set, as this is
# # not a dummy field!
## ...and on a side note, I want them listen in another order (default is
## alphabetically)
# # Since [foo.com] would be interpreted as a host in the domain "com", we
# # specify that this is a domain by adding a semicolon.
# [foo.com;]
# node_order Totals fii.foo.com fay.foo.com
