darkness_08
ich habe gerade gesehen, dass ich mehrere mails in der queue habe. Gefunden habe ich diese Meldung:
Allerdings kann ich mich ohne Probleme mit dem user ispconfig local anmelden.
postfix Log
Jun 4 15:19:37 titan amavis[2218]: (02218-01) (!)connect_to_sql: unable to connect to DSN 'DBI:mysql:database=dbispconfig;host=127.0.0.1;port=3306': Access denied for user 'ispconfig'@'127.0.0.1' (using password: YES)
Jun 4 15:19:37 titan amavis[2218]: (02218-01) (!!)TROUBLE in process_request: connect_to_sql: unable to connect to any dataset at (eval 111) line 247.
Jun 4 15:19:37 titan amavis[2218]: (02218-01) (!)Requesting process rundown after fatal error
postfix Log
Jun 4 15:35:06 titan postfix/smtpd[7521]: connect from mout.web.de[212.227.15.14]
Jun 4 15:35:06 titan postfix/smtpd[7521]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Jun 4 15:35:06 titan postfix/smtpd[7521]: warning: mysql:/etc/postfix/mysql-virtual_client.cf: table lookup problem
Jun 4 15:35:06 titan postfix/smtpd[7521]: NOQUEUE: reject: RCPT from mout.web.de[212.227.15.14]: 451 4.3.5 <mout.web.de[212.227.15.14]>: Client host rejected: Server configuration error; from=<@...> to=<mail@...> proto=ESMTP helo=<mout.web.de>
Jun 4 15:35:06 titan postfix/smtpd[7521]: disconnect from mout.web.de[212.227.15.14]
