Hallo Leute,
ich habe folgendes Problem. Wenn ich über meinem E-Mail Client ein Mail versende funktionierts einwandfrei. Wenn ich an die selbe Adresse ein Mail über meine Website (PHP oder Sendmail) sende, sieht mein Logfile so aus:
Hier meine main.cf:
Und im Anhang noch ein Bildchen von meiner DNS Konfiguration.
Bitte um Hilfe.
Danke und lg,
redi78
Jun 30 12:10:05 server postfix/smtp[25641]: 62B14B010E: to=<rene.diem@noem.at>,
relay=bwmg01.noem.at[62.218.27.145]:25, delay=0.87, delays=0.05/0.11/0.26/0.45,
dsn=5.0.0, status=bounced (host bwmg01.noem.at[62.218.27.145] said: 554 <www-dat
a@server.blasmusikforum.at>: Sender address rejected: MX record not found (in re
ply to RCPT TO command))
Hier meine main.cf:
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# TLS parameters
smtpd_use_tls = yes
# myhostname = server.blasmusikforum.at
myhostname = 85-126-193-250.work.xdsl-line.inode.at
mydestination = server.blasmusikforum.at, localhost, localhost.localdomain
relayhost =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
smtpd_sasl_auth_enable = yes
virtual_create_maildirsize = yes
virtual_maildir_extended = yes
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = "The user you are trying to reach is over quota."
virtual_overquota_bounce = yes
virtual_transport = maildrop
message_size_limit = 0
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
smtp_sasl_security_options =
Bitte um Hilfe.
Danke und lg,
redi78
