heute habe ich folgenden Fehler vom automatischen Cron-Job von Magento erhalten und kann damit leider nichts anfangen:
*** glibc detected *** php: free(): invalid pointer: 0x0a94f718 *** ======= Backtrace: ========= /lib/tls/i686/cmov/libc.so.6(+0x6e341)[0xb7142341]
/lib/tls/i686/cmov/libc.so.6(+0x6fb98)[0xb7143b98]
/lib/tls/i686/cmov/libc.so.6(cfree+0x6d)[0xb7146c7d]
/usr/lib/libxml2.so.2(xmlFreeNodeList+0x134)[0xb727acb4]
/usr/lib/libxml2.so.2(xmlFreeNodeList+0x165)[0xb727ace5]
/usr/lib/libxml2.so.2(xmlFreeDoc+0xc2)[0xb727aa42]
php(php_libxml_decrement_doc_ref+0x58)[0x80a01e8]
php(php_libxml_node_decrement_resource+0x4d)[0x80a046d]
php[0x81a226a]
php(zend_objects_store_del_ref_by_handle_ex+0x2ad)[0x8332fcd]
php(zend_objects_store_del_ref+0x2f)[0x833300f]
php(_zval_dtor_func+0x99)[0x830bb59]
php(_zval_ptr_dtor+0x4d)[0x82ff31d]
php[0x8332476]
php[0x837cd09]
php[0x837d598]
php(execute+0x1ce)[0x8335f3e]
php(zend_execute_scripts+0x66)[0x830be26]
php(php_execute_script+0x1e4)[0x82b0164]
php[0x83a2f58]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6)[0xb70eabd6]
php[0x806b201]
======= Memory map: ========
08048000-08723000 r-xp 00000000 08:01 1704669 /usr/bin/php5
08723000-08760000 r--p 006da000 08:01 1704669 /usr/bin/php5
08760000-08767000 rw-p 00717000 08:01 1704669 /usr/bin/php5
08767000-0877e000 rw-p 00000000 00:00 0
0a6b7000-0b0ca000 rw-p 00000000 00:00 0 [heap]
b5200000-b5221000 rw-p 00000000 00:00 0
b5221000-b5300000 ---p 00000000 00:00 0
b5311000-b5312000 ---p 00000000 00:00 0
b5312000-b5b12000 rw-p 00000000 00:00 0
b5b12000-b5b1c000 r-xp 00000000 08:01 1482824 /lib/tls/i686/cmov/libnss_files-2.11.1.so
b5b1c000-b5b1d000 r--p 00009000 08:01 1482824 /lib/tls/i686/cmov/libnss_files-2.11.1.so
b5b1d000-b5b1e000 rw-p 0000a000 08:01 1482824 /lib/tls/i686/cmov/libnss_files-2.11.1.so
b5b1e000-b5b54000 r-xp 00000000 08:01 1728677 /usr/lib/libxslt.so.1.1.26
b5b54000-b5b55000 r--p 00035000 08:01 1728677 /usr/lib/libxslt.so.1.1.26
b5b55000-b5b56000 rw-p 00036000 08:01 1728677 /usr/lib/libxslt.so.1.1.26
b5b56000-b5b67000 r-xp 00000000 08:01 1728678 /usr/lib/libexslt.so.0.8.15
b5b67000-b5b68000 r--p 00010000 08:01 1728678 /usr/lib/libexslt.so.0.8.15
b5b68000-b5b69000 rw-p 00011000 08:01 1728678 /usr/lib/libexslt.so.0.8.15
b5b69000-b5b6f000 r-xp 00000000 08:01 1205409 /usr/lib/php5/20090626+lfs/xsl.so
b5b6f000-b5b70000 ---p 00006000 08:01 1205409 /usr/lib/php5/20090626+lfs/xsl.so
Was hat es damit auf sich?
Viele Grüße
Hahni
php[0x81a226a]
php[0x8332476]
php[0x837cd09]
php[0x837d598]
php[0x83a2f58]
php[0x806b201]
Viele Grüße
Hahni
