Jailkit sftp-Problem Ubuntu 11.04
daben
ich habe die
The Perfect Server - Ubuntu 11.04-Installation (+ jailkit-2.14) auf einem VPS vorgenommen. Allerdings funktioniert SFTP bei den Jail-Usern nicht:
filezilla-client log:
Antwort:    fzSftp started
Trace:    CSftpControlSocket::ConnectParseResponse(fzSftp started)
Trace:    CSftpControlSocket::SendNextCommand()
Trace:    CSftpControlSocket::ConnectSend()
Befehl:    open "subsonic_user2@penny.example.net" 22
Trace:    psftp: Implicit session load.
Trace:    Looking up host "penny.example.net"
Trace:    Connecting to <ip> port 22
Trace:    Server version: SSH-2.0-OpenSSH_5.8p1 Debian-1ubuntu3
Trace:    Using SSH protocol version 2
Trace:    We claim version: SSH-2.0-PuTTY_Local:_May_22_2011_19:21:03
Trace:    Doing Diffie-Hellman group exchange
Trace:    Doing Diffie-Hellman key exchange with hash SHA-256
Trace:    Host key fingerprint is:
Trace:    ssh-rsa 2048 a4:a0:4c:3a:d8:a0:c0:7b:fa:40:71:2b:ba:06:3f:a2
Trace:    Initialised AES-256 SDCTR client->server encryption
Trace:    Initialised HMAC-SHA1 client->server MAC algorithm
Trace:    Initialised AES-256 SDCTR server->client encryption
Trace:    Initialised HMAC-SHA1 server->client MAC algorithm
Befehl:    Pass: ******************
Trace:    Sent password
Trace:    Access granted
Trace:    Opened channel for session
Trace:    Started a shell/command
Status:    Connected to penny.example.net
Trace:    Server sent command exit status 1
Fehler:    Connection closed by server with exitcode 1
Trace:    CSftpControlSocket::ResetOperation(66)
Trace:    CControlSocket::ResetOperation(66)
Fehler:    Herstellen der Verbindung zum Server fehlgeschlagen
auth.log
[SIZE=1]
Jun 22 10:29:03 penny sshd[23284]: pam_unix(sshd:session): session opened for user [/SIZE][SIZE=1]subsonic_[/SIZE][SIZE=1]user2 by (uid=0)
Jun 22 10:29:03 penny sshd[23296]: subsystem request for sftp by user subsonic_user2
Jun 22 10:29:03 penny jk_chrootsh[23297]: now entering jail /var/www/clients/clientX/webXX for user subsonic_user2 (5005) with arguments -c /usr/lib/openssh/sftp-server
Jun 22 10:29:03 penny sshd[23284]: pam_unix(sshd:session): session closed for user subsonic_user2
[/SIZE]
In der auth.log und ispconfig.log gibt es selbst im Debug-Level keine Auffälligkeiten.
Der Konsolen-Login via ssh funktioniet ohne Probleme
Hat jemand eine Idee was da falsch laufen könnte?
SFTP wird bei jailkit Usern nicht unterstützt, da die sftp Komponenten nicht im jail eingebunden sind. Statt SFTP würde ich empfehlen FTPS zu nehmen, also SSL/TLS verschlüsseltes FTP.
daben
hmmm merkwürdig, bei meinen Debian Lenny / Squeeze - Ispconfig3 - Installationen funktioniert das aber schon. Wurde das erst mit der neuen jailkit-Version entfernt?
Nein, da wurde nichts geändert. Möglicherweise hast Du bei Dir unter Debian die jailkit Konfiguration angepasst?
