möchte gerne meinen Mailserver auf Port 993 IMAP und 465 SMTP laufen lassen. IMAP funktioniert wunderbar jedoch kann ich keine Mails versenden auf Port 465.
System: Debian Squeeze
ISPConfig 3.0.3
Anleitung: Perfect Server Debian Squeeze Bind Dovecot Postfix
Fehler:
main.cf
master.cf
/etc/postfix/sasl/smtp.conf
/etc/default/saslauthd
Bin an dem Problem jetzt schon seit mehreren Tagen. Google konnte bisher auch nicht helfen.
Jemand eine Idee?
Vielen dank und Grüße
ISPConfig 3.0.3
Fehler:
	Oct 30 00:42:21 kweb01 postfix/smtpd[29181]: connect from xxx
Oct 30 00:42:21 kweb01 postfix/smtpd[29181]: setting up TLS connection from xxx
Oct 30 00:42:22 kweb01 postfix/smtpd[29181]: Anonymous TLS connection established from xxx: TLSv1 with cipher DHE-RSA-AES256-SHA (256/256 bits)
Oct 30 00:42:25 kweb01 postfix/smtpd[29181]: warning: SASL authentication failure: Password verification failed
Oct 30 00:42:25 kweb01 postfix/smtpd[29181]: warning: xxx: SASL PLAIN authentication failed: authentication failure
Oct 30 00:42:27 kweb01 postfix/smtpd[29181]: warning: xxx: SASL LOGIN authentication failed: authentication failure
	mydomain = server.example.com
myhostname = server.example.com
mydestination = $myhostname,
    $mydomain,
    localhost.$myhostname,
    localhost.$mydomain,
    localhost
mynetworks = 127.0.0.0/8
inet_interfaces = all
append_dot_mydomain = no
biff = no
default_destination_concurrency_limit = 20
local_destination_concurrency_limit = 2
smtpd_helo_required = yes
smtpd_recipient_restrictions = permit_mynetworks,
    permit_sasl_authenticated,
    reject_unauth_destination,
    reject_unauth_pipelining,
    reject_non_fqdn_recipient,
    reject_unknown_hostname,
    reject_unknown_recipient_domain,
    reject_unknown_sender_domain,
    check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf
    check_policy_service inet:127.0.0.1:60000
message_size_limit = 52428800
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $myhostname
$virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
virtual_mailbox_base = /var/vmail/
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
local_transport = local
alias_maps = $alias_database
mailbox_size_limit = 0
virtual_mailbox_limit = 0
smtp_use_tls = yes
smtpd_use_tls = yes
smtpd_tls_cert_file = /etc/ssl/private/xxx.de.crt
smtpd_tls_key_file = /etc/ssl/private/xxx.pem
smtp_tls_CApath = /etc/ssl/certs
smtpd_tls_auth_only = no
smtpd_tls_loglevel = 1
smtpd_error_sleep_time = 1s
smtpd_soft_error_limit = 20
smtpd_hard_error_limit = 30
debugger_command =
         PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
         ddd $daemon_directory/$process_name $process_id & sleep 5
	smtp      inet  n       -       -       -       -       smtpd
smtps    inet  n       -       -       -       -       smtpd
        -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes
#628       inet  n       -       -       -       -       qmqpd
pickup    fifo  n       -       -       60      1       pickup
cleanup   unix  n       -       -       -       0       cleanup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     fifo  n       -       -       300     1       oqmgr
tlsmgr    unix  -       -       -       1000?   1       tlsmgr
rewrite   unix  -       -       -       -       -       trivial-rewrite
bounce    unix  -       -       -       -       0       bounce
defer     unix  -       -       -       -       0       bounce
trace     unix  -       -       -       -       0       bounce
verify    unix  -       -       -       -       1       verify
flush     unix  n       -       -       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       -       -       -       smtp
relay     unix  -       -       -       -       -       smtp
    -o smtp_fallback_relay=
showq     unix  n       -       -       -       -       showq
error     unix  -       -       -       -       -       error
retry     unix  -       -       -       -       -       error
discard   unix  -       -       -       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       -       -       -       lmtp
anvil     unix  -       -       -       -       1       anvil
scache    unix  -       -       -       -       1       scache
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/bin/maildrop -d vmail ${extension} ${recipient} ${user} ${nexthop} ${sender}
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix    -    n    n    -    2    pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
  ${nexthop} ${user}
dovecot   unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
amavis unix - - - - 2 smtp
        -o smtp_data_done_timeout=1200
        -o smtp_send_xforward_command=yes
127.0.0.1:10025 inet n - - - - smtpd
        -o content_filter=
        -o local_recipient_maps=
        -o relay_recipient_maps=
        -o smtpd_restriction_classes=
        -o smtpd_client_restrictions=
        -o smtpd_helo_restrictions=
        -o smtpd_sender_restrictions=
        -o smtpd_recipient_restrictions=permit_mynetworks,reject
        -o mynetworks=127.0.0.0/8
        -o strict_rfc821_envelopes=yes
        -o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
        -o smtpd_bind_address=127.0.0.1
	pwcheck_method: saslauthd
allowanonymouslogin: no
allowplaintext: yes
mech_list: plain login cram-md5 digest-md5
sql_engine: mysql
sql_hostnames: localhost
sql_user: xxx
sql_passwd: xxx
sql_database: dbispconfig
sql_select: SELECT password FROM mail_user WHERE email='%u@%r'/etc/default/saslauthd
	OPTIONS="-c -m /var/spool/postfix/var/run/saslauthd -r"Jemand eine Idee?
