Hi,
ich habe das problem, dass ich weder mails ausserhalb meines netzwerkes empfangen noch senden kann.
die gebrauchte anleitung ist The Perfect Server – Debian Lenny (Debian 5.0) [ISPConfig 3].
bei meinem domain registrar habe ich nen MX record server.myownhost.org
und nen A record fuer server zu meiner statischen ip.
dig myownhost.org any:
dann mein mail log
soweit ich weiss sind ist port 25 bei meinem isp offen vhe-364601.sshn.net zumindest funktioniert telent vhe-364601.sshn.net 25 & telnet myownhost.org 25.
schonmal bedankt,
Jonas
; <<>> DiG 9.6-ESV-R1 <<>> myownhost.org any
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 44176
;; flags: qr rd ra; QUERY: 1, ANSWER: 6, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;myownhost.org. IN ANY
;; ANSWER SECTION:
myownhost.org. 79363 IN SOA ns1.leaseweb.nl. postmaster.leaseweb.nl. 2010100405 14400 7200 604800 86400
myownhost.org. 79363 IN MX 10 server.myownhost.org.
myownhost.org. 68191 IN A 195.169.203.78
myownhost.org. 79363 IN NS ns4.leaseweb.net.
myownhost.org. 79363 IN NS ns5.leaseweb.nl.
myownhost.org. 79363 IN NS ns1.leaseweb.nl.
;; Query time: 1 msec
;; SERVER: 131.174.78.16#53(131.174.78.16)
;; WHEN: Mon Oct 4 21:06:10 2010
;; MSG SIZE rcvd: 194
dann mein mail log
Oct 4 21:05:01 server pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:05:01 server pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 4 21:05:01 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:05:01 server imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Oct 4 21:05:01 server postfix/smtpd[4557]: connect from localhost.localdomain[127.0.0.1]
Oct 4 21:05:01 server postfix/smtpd[4557]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Oct 4 21:05:01 server postfix/smtpd[4557]: disconnect from localhost.localdomain[127.0.0.1]
Oct 4 21:08:00 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:08:00 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[34706], protocol=IMAP
Oct 4 21:08:00 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=87, sent=391, time=0
Oct 4 21:08:28 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:08:28 server imapd: LOGIN FAILED, user=admin@myownhost.org, ip=[::ffff:127.0.0.1]
Oct 4 21:08:33 server imapd: LOGOUT, ip=[::ffff:127.0.0.1], rcvd=72, sent=332
Oct 4 21:08:44 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:08:44 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53061], protocol=IMAP
Oct 4 21:08:44 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=30, sent=238, time=0
Oct 4 21:08:44 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53062], protocol=IMAP
Oct 4 21:08:44 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=485, sent=1650, time=0
Oct 4 21:08:44 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53064], protocol=IMAP
Oct 4 21:08:44 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=411, body=0, rcvd=296, sent=1812, time=0
Oct 4 21:08:46 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:08:46 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53066], protocol=IMAP
Oct 4 21:08:46 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=411, body=0, rcvd=296, sent=1812, time=0
Oct 4 21:08:48 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:08:48 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53068], protocol=IMAP
Oct 4 21:08:48 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=87, sent=391, time=0
Oct 4 21:09:02 server postfix/smtpd[4621]: connect from localhost.localdomain[127.0.0.1]
Oct 4 21:09:02 server postfix/smtpd[4621]: E0AE85741ED: client=localhost.localdomain[127.0.0.1]
Oct 4 21:09:02 server postfix/cleanup[4628]: E0AE85741ED: message-id=
Oct 4 21:09:02 server postfix/qmgr[3317]: E0AE85741ED: from=, size=760, nrcpt=1 (queue active)
Oct 4 21:09:02 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:02 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53078], protocol=IMAP
Oct 4 21:09:02 server postfix/smtpd[4621]: disconnect from localhost.localdomain[127.0.0.1]
Oct 4 21:09:03 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=638, sent=203, time=1
Oct 4 21:09:03 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:03 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53082], protocol=IMAP
Oct 4 21:09:03 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=411, body=0, rcvd=296, sent=1812, time=0
Oct 4 21:09:09 server postfix/smtpd[4635]: connect from localhost.localdomain[127.0.0.1]
Oct 4 21:09:09 server postfix/smtpd[4635]: 083E45741F2: client=localhost.localdomain[127.0.0.1]
Oct 4 21:09:09 server postfix/cleanup[4628]: 083E45741F2: message-id=
Oct 4 21:09:09 server postfix/qmgr[3317]: 083E45741F2: from=, size=1235, nrcpt=1 (queue active)
Oct 4 21:09:09 server amavis[4307]: (04307-01) Passed CLEAN, LOCAL [127.0.0.1] [195.169.203.78] -> , Message-ID: , mail_id: IV6qr9bNeVfq, Hits: 1.459, size: 760, queued_as: 083E45741F2, 6060 ms
Oct 4 21:09:09 server postfix/smtp[4629]: E0AE85741ED: to=, relay=127.0.0.1[127.0.0.1]:10024, delay=6.1, delays=0.07/0.02/0.01/6.1, dsn=2.0.0, status=sent (250 2.0.0 Ok, id=04307-01, from MTA([127.0.0.1]:10025): 250 2.0.0 Ok: queued as 083E45741F2)
Oct 4 21:09:09 server postfix/qmgr[3317]: E0AE85741ED: removed
Oct 4 21:09:09 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:09 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53091], protocol=IMAP
Oct 4 21:09:09 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=1690, body=0, rcvd=311, sent=4673, time=0
Oct 4 21:09:10 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:10 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53093], protocol=IMAP
Oct 4 21:09:10 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=1690, body=0, rcvd=311, sent=4673, time=0
Oct 4 21:09:10 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53095], protocol=IMAP
Oct 4 21:09:10 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=140, sent=900, time=0
Oct 4 21:09:11 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:11 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53097], protocol=IMAP
Oct 4 21:09:11 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=411, body=0, rcvd=296, sent=1812, time=0
Oct 4 21:09:13 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:13 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53099], protocol=IMAP
Oct 4 21:09:13 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=0, body=1279, rcvd=145, sent=1969, time=0
Oct 4 21:09:17 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:09:17 server imapd: LOGIN, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], port=[53101], protocol=IMAP
Oct 4 21:09:17 server imapd: LOGOUT, user=admin@myownhost.org, ip=[::ffff:127.0.0.1], headers=1690, body=0, rcvd=311, sent=4673, time=0
Oct 4 21:09:39 server postfix/smtp[4639]: connect to mx1.gmx.net[213.165.64.102]:25: Connection timed out
Oct 4 21:10:01 server postfix/smtpd[4621]: connect from localhost.localdomain[127.0.0.1]
Oct 4 21:10:01 server postfix/smtpd[4621]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Oct 4 21:10:01 server postfix/smtpd[4621]: disconnect from localhost.localdomain[127.0.0.1]
Oct 4 21:10:01 server pop3d: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:10:01 server pop3d: Disconnected, ip=[::ffff:127.0.0.1]
Oct 4 21:10:01 server imapd: Connection, ip=[::ffff:127.0.0.1]
Oct 4 21:10:01 server imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
schonmal bedankt,
Jonas
