fahrlehrer
Guten Abend Jungs,
ich habe auf meinem neu aufgesetzten Server (OpenSuse 11.2) das folgende Problem: Ich kann ISPConfig 3 ohne Probleme nutzen um Domains anzulegen und diese zu nutzen. Nur mit den Mails wirds nix. Mailboxen, die ich angelegt habe, werden nicht erreicht folgende Fehlermeldungen erscheinen in der /var/log/mail:
Nov 22 21:13:04 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12315 exit status 1
Nov 22 21:13:04 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:14:04 server1 postfix/trivial-rewrite[12361]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:14:05 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12361 exit status 1
Nov 22 21:14:05 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:15:05 server1 postfix/trivial-rewrite[12454]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:15:06 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12454 exit status 1
Nov 22 21:15:06 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:16:05 server1 postfix/qmgr[11720]: fatal: watchdog timeout
Nov 22 21:16:06 server1 postfix/master[6291]: warning: process /usr/lib/postfix/qmgr pid 11720 exit status 1
Nov 22 21:16:06 server1 postfix/master[6291]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Nov 22 21:16:06 server1 postfix/trivial-rewrite[12498]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:16:07 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12498 exit status 1
Nov 22 21:16:07 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:17:06 server1 postfix/qmgr[12541]: 9266561CEE: from=, size=2187, nrcpt=1 (queue active)
Nov 22 21:17:07 server1 postfix/trivial-rewrite[12542]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:17:08 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12542 exit status 1
Nov 22 21:17:08 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:18:08 server1 postfix/trivial-rewrite[12580]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:18:09 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12580 exit status 1
Nov 22 21:18:09 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:19:09 server1 postfix/trivial-rewrite[12623]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:19:10 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12623 exit status 1
Nov 22 21:19:10 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:20:10 server1 postfix/trivial-rewrite[12688]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:20:11 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12688 exit status 1
Nov 22 21:20:11 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:20:34 server1 clamd[3499]: SelfCheck: Database status OK.
Nov 22 21:21:11 server1 postfix/trivial-rewrite[12720]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:21:12 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12720 exit status 1
Nov 22 21:21:12 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:22:12 server1 postfix/trivial-rewrite[12750]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:22:13 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12750 exit status 1
Nov 22 21:22:13 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:23:13 server1 postfix/trivial-rewrite[12817]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:23:14 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12817 exit status 1
Nov 22 21:23:14 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:24:09 server1 postfix/pickup[10865]: A5F9D61CEF: uid=0 from=
Nov 22 21:24:14 server1 postfix/trivial-rewrite[12892]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:24:15 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12892 exit status 1
Nov 22 21:24:15 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:25:15 server1 postfix/trivial-rewrite[12946]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:25:16 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12946 exit status 1
Nov 22 21:25:16 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:26:16 server1 postfix/trivial-rewrite[12980]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:26:17 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 12980 exit status 1
Nov 22 21:26:17 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:27:17 server1 postfix/trivial-rewrite[13030]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:27:18 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13030 exit status 1
Nov 22 21:27:18 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:28:18 server1 postfix/trivial-rewrite[13065]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:28:19 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13065 exit status 1
Nov 22 21:28:19 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:29:19 server1 postfix/trivial-rewrite[13094]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:29:20 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13094 exit status 1
Nov 22 21:29:20 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:30:20 server1 postfix/trivial-rewrite[13175]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:30:21 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13175 exit status 1
Nov 22 21:30:21 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:30:34 server1 clamd[3499]: SelfCheck: Database status OK.
Nov 22 21:31:21 server1 postfix/trivial-rewrite[13204]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:31:22 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13204 exit status 1
Nov 22 21:31:22 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:32:22 server1 postfix/trivial-rewrite[13233]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:32:23 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13233 exit status 1
Nov 22 21:32:23 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:33:23 server1 postfix/trivial-rewrite[13264]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:33:24 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13264 exit status 1
Nov 22 21:33:24 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:33:45 server1 postfix/qmgr[12541]: fatal: watchdog timeout
Nov 22 21:33:46 server1 postfix/master[6291]: warning: process /usr/lib/postfix/qmgr pid 12541 exit status 1
Nov 22 21:33:46 server1 postfix/master[6291]: warning: /usr/lib/postfix/qmgr: bad command startup -- throttling
Nov 22 21:34:24 server1 postfix/trivial-rewrite[13293]: fatal: open /etc/postfix/transports.cf: No such file or directory
Nov 22 21:34:25 server1 postfix/master[6291]: warning: process /usr/lib/postfix/trivial-rewrite pid 13293 exit status 1
Nov 22 21:34:25 server1 postfix/master[6291]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Nov 22 21:34:46 server1 postfix/qmgr[13298]: 9266561CEE: from=, size=2187, nrcpt=1 (queue active)
Für Hilfen wäre ich sehr dankbar.
