Mailwarteschlange:
-Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient-------
00B87E47B 2938270 Mon Oct 22 22:12:13xxx@t-online.de
(temporary failure. Command output: ERR: authdaemon: s_connect() failed: Permission denied /usr/bin/maildrop: Unable to create a dot-lock at /var/vmail/domain.de/info/15540.0.server.domain.com.)
info@domain.de
067861566C 238877 Tue Oct 23 11:54:47
s.zapf@xxx.de
(host mx12.ihk.de[141.88.222.223] refused to talk to me: 554-mx12.ihk.de 554 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means.)
hoehn-r@domain.de
F0B6CEC8C 18991 Mon Oct 22 22:15:48
xxx@stiebel-eltron.de
(temporary failure. Command output: ERR: authdaemon: s_connect() failed: Permission denied /usr/bin/maildrop: Unable to create a dot-lock at /var/vmail/domain.de/info/13249.0.server.domain.com.)
info@domain.de
F070C50A4 2875098 Mon Oct 22 17:16:31
xxx@demajomurano.com
(temporary failure. Command output: ERR: authdaemon: s_connect() failed: Permission denied /usr/bin/maildrop: Unable to create a dot-lock at /var/vmail/domain.de/info/12198.0.server.domain.com.)
info@domain.de
831A56B9B 554297 Mon Oct 22 17:30:47 NOTESSRV2/xxx@wolf-heiztechnik.de
(temporary failure. Command output: ERR: authdaemon: s_connect() failed: Permission denied /usr/bin/maildrop: Unable to create a dot-lock at /var/vmail/domain.de/info/12203.0.server.domain.com.)
info@domain.de
BBCD6F3A2 121605 Tue Oct 23 00:16:39
newsletter@xxx.de
(temporary failure. Command output: ERR: authdaemon: s_connect() failed: Permission denied /usr/bin/maildrop: Unable to create a dot-lock at /var/vmail/domain.de/info/10840.0.server.domain.com.)
info@domain.de
-- 6592 Kbytes in 6 Requests.
Mail-Protokoll:
Oct 23 11:54:53 server postfix/smtpd[15892]: NOQUEUE: reject: RCPT from srv-exchange.fondation-donbosco.fr[92.103.67.34]: 450 4.1.8 : Sender address rejected: Domain not found; from= to= proto=ESMTP helo=
Oct 23 11:54:53 server postfix/smtpd[15921]: lost connection after DATA from c-71-58-108-153.hsd1.pa.comcast.net[71.58.108.153]
Oct 23 11:54:53 server postfix/smtpd[15921]: disconnect from c-71-58-108-153.hsd1.pa.comcast.net[71.58.108.153]
Oct 23 11:54:53 server postfix/smtpd[15892]: lost connection after RSET from srv-exchange.fondation-donbosco.fr[92.103.67.34]
Oct 23 11:54:53 server postfix/smtpd[15892]: disconnect from srv-exchange.fondation-donbosco.fr[92.103.67.34]
Oct 23 11:54:53 server postfix/smtpd[15964]: connect from srv-exchange.fondation-donbosco.fr[92.103.67.34]
Oct 23 11:54:53 server postfix/smtpd[15964]: NOQUEUE: reject: RCPT from srv-exchange.fondation-donbosco.fr[92.103.67.34]: 450 4.1.8 : Sender address rejected: Domain not found; from= to= proto=ESMTP helo=
Oct 23 11:54:53 server postfix/smtpd[15964]: disconnect from srv-exchange.fondation-donbosco.fr[92.103.67.34]
Oct 23 11:54:53 server pop3d: Disconnected, ip=[::ffff:213.243.107.151]
Oct 23 11:54:53 server pop3d: Connection, ip=[::ffff:213.243.107.151]
Oct 23 11:54:53 server pop3d: LOGIN FAILED, user=root, ip=[::ffff:213.243.107.151]
Oct 23 11:54:58 server postfix/smtpd[15894]: connect from bl18-89-63.dsl.telepac.pt[188.83.89.63]
Oct 23 11:54:58 server postfix/smtpd[15894]: NOQUEUE: reject: RCPT from bl18-89-63.dsl.telepac.pt[188.83.89.63]: 554 5.7.1 Service unavailable; Client host [188.83.89.63] blocked using zen.spamhaus.org;
http://www.spamhaus.org/query/bl?ip=188.83.89.63; from= to= proto=ESMTP helo=
Oct 23 11:54:58 server postfix/smtpd[15894]: lost connection after DATA from bl18-89-63.dsl.telepac.pt[188.83.89.63]
Oct 23 11:54:58 server postfix/smtpd[15894]: disconnect from bl18-89-63.dsl.telepac.pt[188.83.89.63]
Oct 23 11:54:58 server pop3d: Disconnected, ip=[::ffff:213.243.107.151]
Oct 23 11:54:58 server pop3d: Connection, ip=[::ffff:213.243.107.151]
Oct 23 11:54:59 server pop3d: LOGIN FAILED, user=root, ip=[::ffff:213.243.107.151]
Oct 23 11:55:00 server postfix/smtpd[15892]: connect from unknown[94.99.50.101]
Oct 23 11:55:00 server postfix/smtpd[15892]: NOQUEUE: reject: RCPT from unknown[94.99.50.101]: 554 5.7.1 Service unavailable; Client host [94.99.50.101] blocked using zen.spamhaus.org;
http://www.spamhaus.org/query/bl?ip=94.99.50.101; from= to= proto=ESMTP helo=<[94.99.50.101]>
Oct 23 11:55:01 server postfix/smtpd[15892]: lost connection after DATA from unknown[94.99.50.101]
Oct 23 11:55:01 server postfix/smtpd[15892]: disconnect from unknown[94.99.50.101]
Oct 23 11:55:01 server postfix/smtpd[15894]: connect from unknown[174.90.68.170]
Oct 23 11:55:01 server postfix/smtpd[15894]: NOQUEUE: reject: RCPT from unknown[174.90.68.170]: 450 4.7.1 : Helo command rejected: Host not found; from=<> to= proto=ESMTP helo=
Oct 23 11:55:02 server postfix/smtpd[15894]: disconnect from unknown[174.90.68.170]
