jheinze_ibh
Hello,,
I have ispconfig installed on a physical server running several years without any issue. Now I have decided to move this to a new cloud server, running in the IONOS datacenter.
Installation has been made following the link "the perfect server..." without any issues.
But after this, the server seems to stop working after about 12h. the log files shows no unusual events. After rebooting the server through the configuration panel of IONOS, the server seems to run forthe next 12h.
Has anyone experienced such issues and can give me tips or hints.
list of messages before the server hungs up:
I know, this information may not be sufficient, but I have just started my investigation.
thx
Joe
Apr 21 18:00:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:00:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:05:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:05:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:10:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:10:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:15:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:15:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:20:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:20:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:25:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:25:01 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:30:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:30:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:35:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Apr 21 18:35:02 b9f6781 pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Apr 21 18:39:01 b9f6781 VGAuthService[637]: Pref_Init: Using '/etc/vmware-tools/vgauth.conf' as preferences filepath
Apr 21 18:39:01 b9f6781 VGAuthService[637]: Core dump limit set to -1
Apr 21 18:39:01 b9f6781 VGAuthService[637]: Cannot load message catalog for domain 'VGAuthService', language 'C', catalog dir '.'.
Apr 21 18:39:01 b9f6781 VGAuthService[637]: INIT SERVICE
Apr 21 18:39:01 b9f6781 VGAuthService[637]: Using '/var/lib/vmware/VGAuth/aliasStore' for alias store root directory
Apr 21 18:39:01 b9f6781 VGAuthService[637]: LoadCatalogAndSchema: Using '/etc/vmware-tools/vgauth/schemas' for SAML schemas
Apr 21 18:39:01 b9f6781 VGAuthService[637]: LoadPrefs: Allowing 300 of clock skew for SAML date validation
Apr 21 18:39:01 b9f6781 VGAuthService[637]: SAML_Init: Using xmlsec1 1.2.27 for XML signature support
Apr 21 18:39:01 b9f6781 VGAuthService[637]: ServiceNetworkCreateSocketDir: Created socket directory '/var/run/vmware'
Apr 21 18:39:01 b9f6781 VGAuthService[637]: BEGIN SERVICE
Apr 21 18:39:01 b9f6781 rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd. [v8.1901.0]
Apr 21 18:39:01 b9f6781 rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="909" x-info="https://www.rsyslog.com"] start
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] Linux version 4.19.0-8-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.98-1 (2020-01-26)
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.19.0-8-amd64 root=/dev/mapper/vg00-lv01 ro
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] Disabled fast string operations
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Apr 21 18:39:01 b9f6781 kernel: [ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
thx
Joe
