ISPConfig 3.0.5 is available for download. This release is a major release of ISPConfig 3.
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual for ISPConfig 3.0.5 is now available! ***
Version 1.4 for ISPConfig >= 3.0.5 (Date: 02/22/2013)
Author: Falko Timme <ft@falkotimme.com>
373 pages
The manual can be downloaded from these two links:
ISPConfig 3 Manual « ISPConfig – Hosting Control Panel
Version 1.4 Of The ISPConfig 3 Manual (Date: 02/22/2013) Available | HowtoForge - Linux Howtos and Tutorials
What's new in ISPConfig 3.0.5
- APS package installer. See APS Standard for a list of available packages.
- New web backup system which includes the website databases.
- Mailuser login.
- PHP version selector. Use different PHP versions for different websites.
- Subdomains as virtualhost with separate directory inside the directory tree of the main website without rewriting.
- Support for mod_perl2.
- Improved default theme.
- Global search function.
- PHP-FPM support for Apache servers.
- PHP-FPM mode selector in website options.
- Hardened the website folder structure with new folder protection feature and stricter security settings.
- Maintenance mode.
- Password generator.
- Password confirmation fields.
- Directive snippets for Apache, nginx, and PHP can now be saved and be reused for other websites.
- Forms can be submitted by pressing ENTER (you don't have to click the Save button anymore).
- Many more minor feature enhancements and bugfixes.
- IDN domains are converted automatically to / from punicode. (requires PHP idn extension from pecl)
- Mail traffic reporting for dovecot servers.
Special thanks to Marius Cramer from pixcept KG - Büro für Gestaltung und Software-Entwicklung for his contributions to the 3.0.5 ISPConfig release.
- Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.5.tar.gz
- Changelog
=]ISPConfig::ISPConfig 3: Tasklist
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0) and Debian testing
- Ubuntu 7.10 - 12.10
- OpenSuSE 11 - 12.2
- CentOS 5.2 - 6.3
- Fedora 9 - 15
- Installation
Documentation « ISPConfig – Hosting Control Panel
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
How to Update ISPConfig 3 « FAQforge
- Manual update instructions
373 pages
- Mailuser login.
- Maintenance mode.
- Download
- Changelog
- Known Issues:
- BUG Reporting
- CentOS 5.2 - 6.3
- Fedora 9 - 15
- Installation
- Update
ispconfig_update.sh
cd /tmp
cd ispconfig3_install/install
php -q update.php
