ISPConfig 3.0.5-alpha1 available for testing
The first alpha version of the upcoming ISPConfig 3.0.5 release is available for download. Alpha versions are very early versions released for testing purposes, it is not recommended to use them on production systems.
What's new
- APS package installer. See APS Standard for a list of available packages.
- New web backup system which includes the website databases.
- Mailuser login.
- PHP version selector. Use different PHP versions for different websites.
- Subdomains as virtualhost with separate directory inside the directory tree of the main website without rewriting.
- Support for mod_perl2.
- Improved default theme.
- Global search function.
- PHP-FPM support for Apache servers.
- PHP-FPM mode selector in website options.
- Hardened the website folder structure with new folder protection feature and stricter security settings.
- Maintenance mode.
- Password generator.
- Password confirmation fields.
- Directive snippets for Apache, nginx, and PHP can now be saved and be reused for other websites.
- Forms can be submitted by pressing ENTER (you don't have to click the Save button anymore).
- Many more minor feature enhancements and bugfixes.
Detailed Changelog
=]ISPConfig::ISPConfig 3: Tasklist
Download
http://www.ispconfig.org/downloads/ISPConfig-3.0.5-alpha1.tar.gz
Update instructions
cd /tmp
rm -rf /tmp/ispconfig3_install
wget http://www.ispconfig.org/downloads/ISPConfig-3.0.5-alpha1.tar.gz
tar xvfz ISPConfig-3.0.5-alpha1.tar.gz
cd ispconfig3_install/install
php -q update.php
Falcon37
Eine ganz tolle Alpha! :D
Kommt die finale Version u. U. noch dieses Jahr? Ich will ja für die Frage nicht gesteinigt werden, aber fragen kann man ja mal.
ZooL
kommt der APS manager noch mit in die API, bisher konnte ich im SVN nichts dazu an code finden.
Wäre schön wenn ich das nicht selber intigrieren muss ;)
Ansonsten bisher gute Arbeit.
