ISPConfig 3.0.5.4 Patch 1 is available for download. This is a patch release for ISPConfig 3.0.5.4 that fixes some issues that were found in the last version. See changelog below for details.
- Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.5.4p1.tar.gz
- Changelog
=]ISPConfig::ISPConfig 3: Tasklist
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Wheezy (7.0) and Debian testing
- Ubuntu 7.10 - 14.04
- OpenSuSE 11 - 13.1
- CentOS 5.2 - 6.5
- Fedora 9 - 15
- Installation
Documentation
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
A "reconfigure services" is not required for this patch update.
How to Update ISPConfig 3 « FAQforge
- Manual update instructions
- Download
- Changelog
- Known Issues:
- BUG Reporting
- CentOS 5.2 - 6.5
- Fedora 9 - 15
- Installation
Documentation
- Update
ispconfig_update.sh
cd /tmp
cd ispconfig3_install/install
php -q update.php
