ISPConfig 3.0.5.1 is available for download. This release is a bugfix release for ISPConfig 3.0.5.
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual for ISPConfig 3.0.5 is now available! ***
Version 1.4 for ISPConfig >= 3.0.5 (Date: 02/22/2013)
Author: Falko Timme <ft@falkotimme.com>
373 pages
The manual can be downloaded from these two links:
ISPConfig 3 Manual « ISPConfig – Hosting Control Panel
Version 1.4 Of The ISPConfig 3 Manual (Date: 02/22/2013) Available | HowtoForge - Linux Howtos and Tutorials
- Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.5.1.tar.gz
- Changelog
=]ISPConfig::ISPConfig 3: Tasklist
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0) and Debian testing
- Ubuntu 7.10 - 12.10
- OpenSuSE 11 - 12.2
- CentOS 5.2 - 6.3
- Fedora 9 - 15
- Installation
Documentation « ISPConfig – Hosting Control Panel
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
How to Update ISPConfig 3 « FAQforge
- Manual update instructions
373 pages
- Download
- Changelog
- Known Issues:
- BUG Reporting
- CentOS 5.2 - 6.3
- Fedora 9 - 15
- Installation
- Update
ispconfig_update.sh
cd /tmp
cd ispconfig3_install/install
php -q update.php
