ISPConfig 3.0.3.3 released
ISPConfig 3.0.3.3 is available for download. This release is a bugfix release for ISPConfig 3.0.3.
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual is now available! ***
Version 1.1 for ISPConfig >= 3.0.3.1 (Date: 12/12/2010)
Author: Falko Timme <ft@falkotimme.com>
305 pages
The manual can be downloaded from these two links:
http://www.ispconfig.org/ispconfig-3/ispconfig-3-manual/
http://www.howtoforge.com/download-the-ispconfig-3-manual
- Download
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.3.3.tar.gz?use_mirror=
- Changelog
http://bugtracker.ispconfig.org/index.php?do=index&tasks=&project=3&due=51&status[]=
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0)
- Ubuntu 7.10 - 10.10
- OpenSuSE 11 - 11.4
- CentOS 5.2 - 5.6
- Fedora 9 - 14
- Installation
http://www.ispconfig.org/ispconfig-3/documentation/
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
http://www.faqforge.com/linux/controlpanels/ispconfig3/how-to-update-ispconfig-3/
- Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
