ISPConfig 3.0.3.1 released
ISPConfig 3.0.3.1 is available for download. This release is a bugfix release for ISPConfig 3.0.3.
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual is now available! ***
Version 1.1 for ISPConfig 3.0.3.1 (Date: 12/12/2010)
Author: Falko Timme <ft@falkotimme.com>
305 pages
The manual can be downloaded from these two links:
http://www.ispconfig.org/ispconfig-3/ispconfig-3-manual/
http://www.howtoforge.com/download-the-ispconfig-3-manual
Download
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.3.1.tar.gz?use_mirror=
Changelog
http://bugtracker.ispconfig.org/index.php?do=index&tasks=&project=3&due=48&status[]=
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0)
- Ubuntu 7.10 - 10.10
- OpenSuSE 11 - 11.3
- CentOS 5.2 - 5.5
- Fedora 9 - 14
Installation
http://www.ispconfig.org/ispconfig-3/documentation/
Update
ispconfig_update.sh
Select "stable" as update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
http://www.faqforge.com/linux/controlpanels/ispconfig3/how-to-update-ispconfig-3/
Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
F4RR3LL
Active Member
Update Problemlos, keinerlei Warnings / Fehlermeldungen o.ä
Alles läuft stabil.
Wie immer super Arbeit. Danke.
Laubie
Kann ich nur unterschreiben.
Erst aufm Testrechner gemacht, dann aufm Produktivsysstem.
Alles super!
Nur was mir auffiel:
Ich hab auf dem Testrechner das "ISPConfig Update" aus der GUI probiert.
Im ISC-Protokoll fand ich dann diese Fehlermeldung.
--2010-12-14 13:02:02-- http://www.ispconfig.org/downloads/ISPConfig-3.0.3.1.tar.gz
Resolving www.ispconfig.org... 78.46.59.59
Connecting to www.ispconfig.org|78.46.59.59|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2010-12-14 13:02:03 ERROR 404: Not Found.
tar: ISPConfig-3.0.3.1.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
Could not open input file: autoupdate.php
rm: cannot remove `/tmp/ISPConfig-3.0.3.1.tar.gz': No such file or directory
rm: cannot remove `/tmp/ispconfig3_install': No such file or directory
Kann jetzt auch irgendwie an meinem Testrechner liegen, denn manuell mit ispconfig_update.sh lief es problemlos durch.
Wollte es aber nicht verheimlichen ;)
Grüße
Laubie
Problem ist bekannt und steht auch schon im Bugtracker. das Update funktioniert aber trotzdem.
Generell würde ich das Update immer über die Shell einspielen so wie es in den release notes steht und nicht über ispconfig oberfläche.
Laubie
ich glaub, ich muss mir diesen bugtracker echt mal anschauen ;)
Wollte die Funktion mal ausprobieren.
Generell gefällt mir das über die Konsole aber auch immer besser, da man nur so die Meldungen des Systems in Echtzeit mitbekommt.
Grüße
Laubie
