ISPConfig 3.0.2 is available for download. This release is a major release of the ISPConfig 3 Hosting Control panel which brings many new features, improves the functionality and contains fixes for several bugs.
Download
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.2.tar.gz?use_mirror=
Changelog and list of new features
http://bugtracker.ispconfig.org/index.php?do=index&tasks=&project=3&due=21&status[]=
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Lenny (5.0)
- Ubuntu 7.10 - 9.10
- OpenSuSE 11 - 11.2
- CentOS 5.2 - 5.4
- Fedora 9 - 12
Installation
http://www.ispconfig.org/documentation.htm
Update
ispconfig_update.sh
select "stable" as update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
http://www.faqforge.com/linux/controlpanels/ispconfig3/how-to-update-ispconfig-3/
Manual update instructions
Download
Known Issues:
BUG Reporting
- CentOS 5.2 - 5.4
- Fedora 9 - 12
Installation
Update
ispconfig_update.sh
cd /tmp
cd ispconfig3_install/install
php -q update.php
