ISPConfig 3.0.1.4 is available for download. This release is a bugfix release for ISPConfig 3.
Download
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.1.4.tar.gz?use_mirror=
Changes:
- Several bugs have been fixed, see bugtracker:
http://bugtracker.ispconfig.org/index.php?string=&project=3&due[]=27&status[]=closed&do=index
For a detailed changelog, please have a look at the SVN history with an SVN client of your choice:
svn://svn.ispconfig.org/ispconfig3/trunk/
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Lenny (5.0)
- Ubuntu 7.10 - 9.04
- OpenSuSE 11 - 11.1
- CentOS 5.2 - 5.3
- Fedora 9 - 10
Installation
http://www.ispconfig.org/documentation.htm
Update
ispconfig_update.sh
And select "stable" as update resource. The script will check if an updated version of ISPConfig 3 is available
and then download the tar.gz and start the setup script.
If the ISPConfig version on your server does not have this script yet, follow the manual update instructions
below.
Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
Download
Changes:
Known Issues:
BUG Reporting
- CentOS 5.2 - 5.3
- Fedora 9 - 10
Installation
Update
ispconfig_update.sh
below.
cd /tmp
php -q update.php
