ISPConfig 3.0.1.3 is available for download. This release is a bugfix release for ISPConfig 3.
Download
http://downloads.sourceforge.net/ispconfig/ISPConfig-3.0.1.3.tar.gz?use_mirror=
Changes:
- Several bugs have been fixed, see bugtracker:
http://bugtracker.ispconfig.org/index.php?string=&project=3&due[]=26&status[]=closed&do=index
For a detailed changelog, please have a look at the SVN history with an SVN client of your choice:
svn://svn.ispconfig.org/ispconfig3/trunk/
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Lenny (5.0)
- Ubuntu 7.10 - 9.04
- OpenSuSE 11 - 11.1
- CentOS 5.2 - 5.3
- Fedora 9 - 10
Installation
http://www.ispconfig.org/documentation.htm
and in the text files (named INSTALL_*.txt) which are inside the docs folder of the .tar.gz file.
Update
ispconfig_update.sh
And select "stable" as update resource. The script will check if an updated version of ISPConfig 3 is available and
then download the tar.gz and start the setup script.
Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
Download
Changes:
Known Issues:
BUG Reporting
- CentOS 5.2 - 5.3
- Fedora 9 - 10
Installation
Update
ispconfig_update.sh
cd /tmp
php -q update.php
