ISPConfig 3.0.0.8 RC1 released
ISPConfig 3.0.0.8 RC1 is available for download. This release is
the first release candidate for the upcoming ISPConfig 3.0.1 final.
ISPConfig 3 is a new Hosting Control Panel rewritten from scratch. ISPConfig 3
is not a direct update for ISPConfig 2. Do not install it on a ISPConfig 2 server.
Features of ISPConfig 3 compared to ISPConfig 2
- Support for virtual mail users
- Support for virtual FTP Users
- Support for multiple Servers
- Support for splitting of services to multiple servers
(Database, web, FTP and DNS can be on different servers).
Download
The software itself can be downloaded here:
http://www.ispconfig.org/downloads/ISPConfig-3.0.0.8-rc1.tar.gz
ISPConfig 3.0.0.8 rc1 is also available as ready to run VMWare virtual
machine based on Debian 4.0.
Download of the VMWare image:
http://www.applianceforge.com/appliance/19 (approx. 600 MB)
When you run the vmware image the first time you will be asked to keep
or create a MAC address. Select "keep", otherwise the networking wont work.
The root password of the VM is set to "ispconfig", the IP address is
192.168.0.105 and has to be reconfigured in /etc/network/interfaces
to meet your network requirements. The ISPconfig Interface login is:
http://192.168.0.105:8080/
User = admin
Password = admin.
Changes:
- Added a Wizard for DNS records
- Added new database replication mechanism for multiserver setups
- Added function to change the language of the interface witout the need to re login.
- Added ini style settings for the interface part
- Redirect destination after logout is configurable now
- Added merging function in language file editor.
- Software package installer for ispconfig software addons.
- Many enhancements in the monitor module
- Open jobs in jobqueue are now listed in interface
- Many bugs were fixed, see bugtracker:
http://bugtracker.ispconfig.org/index.php?string=&project=3&due[]=13&status[]=closed&do=index
For a detailed changelog, please have a look at the SVN history with a SVN client of your choice:
svn://svn.ispconfig.org/ispconfig3/trunk/
Known Issues:
Please have a look at the bugtracker:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) and Debian Lenny
- Ubuntu 7.10 - 8.10
- OpenSuSE 11 (experimental)
- CentOS 5.2 (experimental)
- Fedora 9 (experimental)
Installation
The installation instructions for ISPConfig can be found in the text files (named INSTALL_*.txt)
which are inside the ISPConfig-3.0.0.8-rc1.tar.gz file.
Update
ispconfig_update_from_svn.sh
