ISPConfig 3.0.0.6 Beta released
Schau mal ins mail.log. Zum Testen solltest Du immer erstmal versuchen Dir eine Mail Lokal zuzustellen, also Dass Du eine Mail von einem lokalen account and sen selben account schickst.
VoodooManiax
Hallo Till,
danke erstmal für die schnelle Antwort. Interner Mail Versand leider auch nicht möglich.
Scheint mir aber ein Problem in ClamAV zu sein, korrigiere mich wenn ich mich da täusche.
Hier ein Auszug aus der mailerror.log:
Sep  9 11:30:19 rootconfig amavis[28450]: (28450-01) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:30:19 rootconfig amavis[28450]: (28450-01) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:30:27 rootconfig amavis[28404]: (28404-03) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:30:27 rootconfig amavis[28404]: (28404-03) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:30:27 rootconfig amavis[28450]: (28450-02) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:30:27 rootconfig amavis[28450]: (28450-02) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:35:42 rootconfig amavis[28404]: (28404-03) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:35:42 rootconfig amavis[28404]: (28404-03) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:35:42 rootconfig amavis[28450]: (28450-02) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:35:42 rootconfig amavis[28450]: (28450-02) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:35:49 rootconfig amavis[28404]: (28404-04) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:35:49 rootconfig amavis[28404]: (28404-04) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:35:49 rootconfig amavis[28450]: (28450-03) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:35:49 rootconfig amavis[28450]: (28450-03) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:41:04 rootconfig amavis[28404]: (28404-04) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:41:04 rootconfig amavis[28404]: (28404-04) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:41:04 rootconfig amavis[28450]: (28450-03) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:41:04 rootconfig amavis[28450]: (28450-03) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:41:11 rootconfig amavis[28404]: (28404-05) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:41:11 rootconfig amavis[28404]: (28404-05) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:41:11 rootconfig amavis[28450]: (28450-04) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:41:11 rootconfig amavis[28450]: (28450-04) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:44:14 rootconfig amavis[2534]: (02534-01) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:44:14 rootconfig amavis[2534]: (02534-01) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:44:14 rootconfig amavis[2533]: (02533-01) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:44:14 rootconfig amavis[2533]: (02533-01) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:49:28 rootconfig amavis[2534]: (02534-01) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:49:28 rootconfig amavis[2534]: (02534-01) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:49:28 rootconfig amavis[2533]: (02533-01) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:49:28 rootconfig amavis[2533]: (02533-01) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:49:35 rootconfig amavis[2534]: (02534-02) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:49:35 rootconfig amavis[2534]: (02534-02) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:49:35 rootconfig amavis[2533]: (02533-02) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:49:35 rootconfig amavis[2533]: (02533-02) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:54:50 rootconfig amavis[2534]: (02534-02) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:54:50 rootconfig amavis[2534]: (02534-02) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:54:50 rootconfig amavis[2533]: (02533-02) (!!) ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:54:50 rootconfig amavis[2533]: (02533-02) (!!) TROUBLE in check_mail: virus_scan FAILED: virus_scan: ALL VIRUS SCANNERS FAILED: ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.; ClamAV-clamscan av-scanner FAILED: /usr/bin/clamscan timed out at (eval 48) line 462.
Sep  9 11:55:18 rootconfig amavis[2534]: (02534-03) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:55:18 rootconfig amavis[2534]: (02534-03) (!!) WARN: all primary virus scanners failed, considering backups
Sep  9 11:55:18 rootconfig amavis[2533]: (02533-03) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 48) line 268.
Sep  9 11:55:18 rootconfig amavis[2533]: (02533-03) (!!) WARN: all primary virus scanners failed, considering backups
Ruff bitte mal auf:
apt-get update
apt-get -u upgrade
umd alle aktuellen Pakete von Debian zu installieren, für den Fall dass da was für ClamAV dabei ist.
Dann start mal Clamav neu:
/etc/init.d/clamd restart
VoodooManiax
die aktuellen Pakete habe ich auch bereits installiert, dennoch ist kein mailversand möglich. zudem lasse ich eine kopie der mails immer auf dem server. auch diese kopien sind weg.
mail.log ist bei mir 15 mb groß. sehe ich zum ersten mal.
sonst noch ne idee ???
Morpheus150785
ftp Problem
Hallo hab das Problem das ich nichts mit meinen FTP Client auf meine Seite laden kann.
FTp User ist erstellt. FTP Client verbindet auch zur Seite. Aber sobald ich was hochladen will. Kommt ein Fehler das ich keine berechtigung habe.
Woran kann das liegen?
Aktualisier bitte mal auf die neueste Version indem Du Folgenden Befehl auf der Shell ausführst:
ispconfig_update_from_svn.sh
Dann Lösche den FTP User und lege ihn neu an. Besteht das Problem dann immer noch?
Morpheus150785
also lag wohl nicht an der ISPConfig version, sondern an meinem FTP Programm. Da war irgendwie als Verbindungsmodus aktiv eingestellt. Nach dem ich auf Standart gegangen bin, ging alles.
Hab das mal versucht weil es nach dem update auch nicht ging.
Dennoch danke für die hilfe.
