Jan 30 19:00:39 chicago300 postfix/smtp[32667]: 7202849E439: to=<janina.nina26@googlemail.com>, relay=127.0.0.1[127.0.0.1]:10024, delay=60527, delays=60485/6.4/0.01/36, dsn=4.5.0, status=deferred (host 127.0.0.1[127.0.0.1] said: 451 4.5.0 From MTA([127.0.0.1]:10025) during fwd-connect (Negative greeting: at (eval 84) line 555, <GEN27> line 406.): id=31958-07 (in reply to end of DATA command))
Jan 30 19:00:54 chicago300 amavis[32107]: (32107-06-2) (!)rw_loop: leaving rw loop, no progress
Jan 30 19:00:55 chicago300 amavis[31958]: (31958-07-2) (!)rw_loop: leaving rw loop, no progress
Jan 30 19:01:03 chicago300 postfix/smtpd[32757]: warning: SASL: Connect to private/auth failed: No such file or directory
Jan 30 19:01:03 chicago300 postfix/smtpd[32757]: fatal: no SASL authentication mechanisms
Jan 30 19:01:03 chicago300 postfix/smtpd[32759]: warning: SASL: Connect to private/auth failed: No such file or directory
Jan 30 19:01:03 chicago300 postfix/smtpd[32759]: fatal: no SASL authentication mechanisms
Jan 30 19:01:03 chicago300 postfix/smtpd[32760]: warning: SASL: Connect to private/auth failed: No such file or directory
Jan 30 19:01:03 chicago300 postfix/smtpd[32760]: fatal: no SASL authentication mechanisms
Jan 30 19:01:03 chicago300 postfix/smtpd[32761]: warning: SASL: Connect to private/auth failed: No such file or directory
Jan 30 19:01:03 chicago300 postfix/smtpd[32761]: fatal: no SASL authentication mechanisms
Jan 30 19:01:04 chicago300 postfix/master[3165]: warning: process /usr/lib/postfix/smtpd pid 32757 exit status 1
Jan 30 19:01:04 chicago300 postfix/master[3165]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Jan 30 19:01:04 chicago300 postfix/master[3165]: warning: process /usr/lib/postfix/smtpd pid 32759 exit status 1
Jan 30 19:01:04 chicago300 postfix/master[3165]: warning: process /usr/lib/postfix/smtpd pid 32760 exit status 1
Jan 30 19:01:04 chicago300 amavis[32107]: (32107-06-2) (!)FWD via SMTP: <www-data> -> <webmaster@spiele-und-musik.eu>, 451 4.5.0 From MTA([127.0.0.1]:10025) during fwd-connect (errno=): id=32107-06-2
Jan 30 19:01:04 chicago300 amavis[32107]: (32107-06-2) Blocked MTA-BLOCKED, <www-data> -> <webmaster@spiele-und-musik.eu>, Message-ID: <20110129231149.031CB49E40A@chicago300.server4you.de>, mail_id: EH5YiHDkW3lU, Hits: 2.195, size: 624, 25970 ms
Jan 30 19:01:04 chicago300 amavis[31958]: (31958-07-2) (!)FWD via SMTP: <webmaster@spiele-und-musik.eu> -> <xx_Katze_xx2000@Yahoo.de>, 451 4.5.0 From MTA([127.0.0.1]:10025) during fwd-connect (errno=): id=31958-07-2
Jan 30 19:01:04 chicago300 amavis[31958]: (31958-07-2) Blocked MTA-BLOCKED, <webmaster@spiele-und-musik.eu> -> <xx_Katze_xx2000@Yahoo.de>, quarantine: K/badh-KYQzpxew+hIb, Message-ID: <20110130071006.EE8F849E483@chicago300.server4you.de>, mail_id: KYQzpxew+hIb, Hits: 1.443, size: 690, 25073 ms
Jan 30 19:01:04 chicago300 postfix/master[3165]: warning: process /usr/lib/postfix/smtpd pid 32761 exit status 1
Jan 30 19:01:05 chicago300 postfix/smtp[32666]: 031CB49E40A: to=<webmaster@spiele-und-musik.eu>, relay=127.0.0.1[127.0.0.1]:10024, conn_use=2, delay=67757, delays=67689/42/0/26, dsn=4.5.0, status=deferred (host 127.0.0.1[127.0.0.1] said: 451 4.5.0 From MTA([127.0.0.1]:10025) during fwd-connect (errno=): id=32107-06-2 (in reply to end of DATA command))
Jan 30 19:01:05 chicago300 postfix/smtp[32667]: EE8F849E483: to=<xx_Katze_xx2000@Yahoo.de>, relay=127.0.0.1[127.0.0.1]:10024, conn_use=2, delay=39058, delays=38991/42/0/25, dsn=4.5.0, status=deferred (host 127.0.0.1[127.0.0.1] said: 451 4.5.0 From MTA([127.0.0.1]:10025) during fwd-connect (errno=): id=31958-07-2 (in reply to end of DATA command))
Jan 30 19:04:25 chicago300 postfix/scache[32730]: statistics: start interval Jan 30 19:00:03
Jan 30 19:04:25 chicago300 postfix/scache[32730]: statistics: domain lookup hits=2 miss=2 success=50%
Jan 30 19:04:25 chicago300 postfix/scache[32730]: statistics: address lookup hits=0 miss=2 success=0%
Jan 30 19:04:25 chicago300 postfix/scache[32730]: statistics: max simultaneous domains=1 addresses=1 connection=2
